Author Topic: PIR Testing  (Read 1567 times)
Offline MotoDanTopic starter
PIR Testing
« on: June 13, 2023, 03:08:11 am »
Does anyone have any experience with production testing of Passive Infrared (PIR) sensors? My current method is to illuminate the sensor with a small filament lamp with the PIR in an enclosed hood. The test works about 90-95%of the time, but some sensors won’t respond to the light, but will to hand motion. I’ve tried various wavelength LED’s including visible and IR. The filament lamp works the best so far, but is not perfect. My research indicates that PIR sensors are designed to be sensitive to radiation with wavelengths in the 8-14 um or “far infrared” range.
The PiR under test is the Senba BS412,
https://www.nysenba.com/pir/bs412.html
Thanks!
Offline mjs
Re: PIR Testing
« Reply #1 on: June 13, 2023, 05:55:43 am »
The detector has two elements inside and it's the difference of those in thermal radiation that triggers it.
If the detector is without a lens:
- illuminate the other half with a bulb or heater resistor (like 5W resistor dissipating 4W) at 5-20cm distance
- add a shutter that opens slowly right in front of detector, exposing first the other half and then the other
If there is a lens:
- Have a warmed up +10°C over ambient painted (not clear metal, as its emissivity is low) plate in front of sensor (50-100cm)
- Add similar shutter closer to the plate rather then closer to the plate
Doing this well without moving parts may be difficult depending on the frequency (or rather time) response of the sensor electronics.
