Author Topic: Relay Specification  (Read 353 times)
Offline sdancer75Topic starter
  • Country: gr
Relay Specification
« on: October 20, 2025, 06:26:55 pm »
This attached relay has the following specs
1. Coil trigger voltage 9V
2. 10A when 240VAC between contacts
3. 10A when 24VDC between contacts
The questions is what 10A/120VAC & 7A/240AC at the right side means?
Is the above a safe replacement for this?
2680423-1
« Last Edit: October 20, 2025, 06:34:04 pm by sdancer75 »
Offline gamalot
  • Correct my English
    • Youtube
Re: Relay Specification
« Reply #1 on: October 20, 2025, 07:31:47 pm »
Their coils have the same nominal voltage and resistance, so they should be swappable without any issues.
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
