I fixed the stlink vdd-target. There was missing R9. Now it uses 32bit flash writes but failed again:
# st-flash write /tmp/open-5012h.bin 0x8000000
st-flash 1.6.1
2020-07-20T10:34:48 INFO common.c: F4xx: 192 KiB SRAM, 512 KiB flash in at least 16 KiB pages.
file /tmp/open-5012h.bin md5 checksum: f996eee3dccbc7f318a3bde681d79faa, stlink checksum: 0x00343fb5
2020-07-20T10:34:48 INFO common.c: Attempting to write 34756 (0x87c4) bytes to stm32 address: 134217728 (0x8000000)
EraseFlash - Sector:0x0 Size:0x4000 2020-07-20T10:34:48 INFO common.c: Flash page at addr: 0x08000000 erased
EraseFlash - Sector:0x1 Size:0x4000 2020-07-20T10:34:48 INFO common.c: Flash page at addr: 0x08004000 erased
EraseFlash - Sector:0x2 Size:0x4000 2020-07-20T10:34:48 INFO common.c: Flash page at addr: 0x08008000 erased
2020-07-20T10:34:48 INFO common.c: Finished erasing 3 pages of 16384 (0x4000) bytes
2020-07-20T10:34:48 INFO common.c: Starting Flash write for F2/F4/L4
2020-07-20T10:34:48 INFO flash_loader.c: Successfully loaded flash loader in sram
enabling 32-bit flash writes
2020-07-20T10:34:49 ERROR flash_loader.c: flash loader run error
2020-07-20T10:34:49 ERROR common.c: stlink_flash_loader_run(0x8000000) failed! == -1
stlink_fwrite_flash() == -1
I think my gd32f407 is corrupted. I disabled switching to high speed clock (in sys_init()). The display remains on. The scope hangs at different points. The relay switches never, once or two times after power on. The best situation I caught is 3/4 of scale on the display.
