Author Topic: Root Sum Squared Error Analysis  (Read 14848 times)
Offline SteveThackery
  • 50 year novice
Re: Root Sum Squared Error Analysis
« Reply #50 on: May 08, 2025, 07:38:19 pm »
Unless you have specific knowledge about the process, it is an assumption. Some might even call it a wild guess.
Knowledge is often not absolute; we think some things are probably true, we're pretty sure of other things and we're almost completely sure of other things. Recognizing and being cognizant of this is essential to any scientist or engineer. We need to keep straight in our own mind what we know to be true and what we guess to be true.
Some people willfully choose to believe whatever feels right. Let's try to avoid that. It leads to misunderstanding at best and conspiracy theories at worst.
1/ Perfectly good point. As I have mentioned earlier, I was actually taught all the stuff I've been saying at college. I've also said it was a long time ago (late '80s to early' 90s). Back then, binning worked as I've described, with the unusual effects on tolerance distributions.
2/ I've also said that I don't know if binning is used today, although I suspect (but don't know) it must be for the really tight tolerances (0.1%, etc).
3/ Finally, if binning is used, I don't see how it could be significantly different in implementation or effect from how it used to be forty years ago. So far nobody has offered a convincing alternative.
My first paragraph is simply a true account of my past, and as such isn't really open to argument. My second paragraph is simply a statement of my opinion, and as such is no better or worse than any other. My third paragraph is where some new insights might be gained. If anyone can think of a binning regime that is substantially different in terms of results from the system I've described, that would be a great thing to discuss. I am totally open to it.
In closing, I was interested to see that Dave (in the video) also said how incredibly difficult it is to find any hard information on how present day resistors are classified in terms of their tolerance, and what the distribution curves look like.
« Last Edit: May 08, 2025, 07:43:42 pm by SteveThackery »
If it ain't broke, keep fixing it until it is.
Online Tation
  • Country: pt
« Reply #51 on: May 08, 2025, 08:36:50 pm »
Anyway, I have definitely :horse: at this point.  And let me paraphrase George Box: “ALL MODELS ARE WRONG, BUT SOME ARE USEFUL.”  So hopefully there is something useful here to the OP question.
The PDF of the sum of 2 random variables is the convolution of their PDFs, so:
1) the convolution of 2 gaussians is another gaussian => OK
2) the convolution of 2 rectangles is a trapezoid. If the rectangles are equal width, degenerates into a triangle. If are much dissimilar, degenerates into the wider one with not vertical sides. => OK
3) each tail may resemble a triangle. Convoluting 2 triangles gives a bell shaped, 3 order (may vary) spline, starts to look gaussian => OK
« Last Edit: May 09, 2025, 09:59:29 am by Tation »
The following users thanked this post: bdunham7
Online bdunham7
« Reply #52 on: May 08, 2025, 08:43:39 pm »
I mentioned it a few posts back.  Suppose you want to select for +/-1.0% but your binning method or device has a 0.5% maximum error (unspecified distribution, you can add that in later).  If the goal is to end up with all resistors within the 1.0%, you are much more concerned with a false accept than a false reject.  If you have a resistor at say -1.5% but the machine made an error of +0.5%, then you'd have a false accept and an out of tolerance product.  So you might set the threshold for +/- 0.5%, this would mean that anything beyond +/- 1% would surely be rejected, but also some resistors that are in tolerance will also be rejected.  The probability of a false reject depends on the exact value of the resistor.  One with -0.9% would very likely be rejected, one with +0.1% would very likely be accepted.  Resistors at exactly 0.0% would always be accepted, those at the extremes would almost always be rejected.  What sort of distribution would the resulting batch of resistors have?  Now you may see that the answer to that question depends on the earlier question about the distribution of the binning machine error.
The following users thanked this post: SteveThackery
  • 50 year novice
« Reply #53 on: May 08, 2025, 09:38:04 pm »
Just a quick point: surely in reality the accuracy of the binning machine would significantly exceed that of the resistors it is binning. I mean, like an order of magnitude, maybe?
Even so, your suggestion looks good. I'll have to take some time to think about it.
Online bdunham7
« Reply #54 on: May 08, 2025, 10:41:01 pm »
It depends on the numbers.  If you make 1M 1% current sense resistors and you need 1000 selected for 0.1%, it may be easier to make a machine that measures to 0.05% than 0.01%, especially if you consider throughput.  Think about what it takes to measure resistance that accurately with a high-end DMM.  The binning process will probably use a good DMM or close derivative of one plus an automated feed fixture.
Offline eugene
« Reply #55 on: May 08, 2025, 11:06:08 pm »
I have no actual knowledge of how binning is or ever was performed, but the way that I always imagined binning of, say, the E series resistors of yore was that a collection of components were sorted into bins corresponding to one of the series (E6, E12, E24, ...) Note that the requirement for binning here is that there is one and only one bin for every possible value. In other words no (significant) overlap and no gaps between bins. With E6 there are 6 bins per decade, etc.
So it makes no sense to try to bin two series at the same time, or even sequentially. If you bin for E24 then all of the resistors will go into one bin or another. There will not be any left over to bin E12. So the popular claim that 100 ohm parts from the E12 series (10%) will not have any within 5% of 100 ohms (because those parts went into the E24 5% bin) makes no sense to me. It implies that the the 82 and 110 ohm E24 bins are empty (all of those components went into the 100 ohm E6 bin.) Wait, what? This is confusing, sure. Like I said, the only thing that makes sense to me is that you bin a collection of parts for one tolerance only. If you want a different tolerance, then you start with a different collection of parts. Consequently, there will be no "holes" in the middle of the distribution.
90% of quoted statistics are fictional
Offline edbaTopic starter
« Reply #56 on: May 09, 2025, 07:14:23 am »
Even though I started this post I am now thinking there are so many assumptions being made about distribution shape, binning etc. when all we really know is what the manufacturer is stating in their datasheet; that the value can be nominal or nominal - tolerance or nominal + tolerance. To say it another way if we don't really know how the values are distributed so must assume worst case. In engineering there are only yes, no or I don't know answers. If you don't know then go and find out and if you can't find out then make an educated guess. So maybe it is the end of the road for RSS?
Offline iMo
  • Country: li
« Reply #57 on: May 09, 2025, 09:52:42 am »
..So maybe it is the end of the road for RSS?
I have here a P&P wheel with X thousands of 0805 0R 5% resistors. It is statistically relevant number so perhaps after binning them we may get how the distribution is like..
 ;D
  • 50 year novice
« Reply #58 on: May 09, 2025, 09:30:08 pm »
I think this is a great suggestion and it does make sense. I have a question: are E12 resistors (for example) always the same tolerance? And do E24 resistors always have a twice-as-tight tolerance than E12? I ask, because that is implied the system you describe. In that system, no resistor is rejected because the bins in any series all join up without gaps.
Online TimFox
« Reply #59 on: May 09, 2025, 09:58:20 pm »
E12 and E24 are two sequences of component values, where E12 is convenient for 10% tolerance and E24 is convenient for 5% tolerance components.
However, it is common (not always done) to see components in a given series with tighter tolerances (e.g., 1%) available as standard products in E24 values.
Offline eugene
« Reply #60 on: May 09, 2025, 10:37:37 pm »
The E series system goes way back to the days where carbon comp was used for most applications. Wire wound resistors were available, but were mostly used wjere higher performance was required and much higher cost could be justified. Anyway, E6 was typically considered 20% (OMG!), E12 10%, and E24 5%. Those were the common options available. The system may have been developed for the benefit of manufacturers but it was mainly advertised as a way for engineers to choose a value. So if the engineer calculated a desired value and decided that 10% was good enough, then they would find the closest E12 bin and write that value on the (hand drawn) schematic. The idea, from the engineer's perspective, was that no matter what value they calculated to be ideal, it always fall within tolerance of some existing value in any series. In those days, most of the resistors were 10% (E12) with more critical parts being 5% (E24). Only special applications required wire wound precision resistors. (Check out the schematics of the 500 series Tektronix scopes. Those guys knew what they were doing!)
  • 50 year novice
« Reply #61 on: May 10, 2025, 12:51:13 pm »
Ah, dammit, so that puts us back to close to where we were. I think @eugene's proposal is ingenious, but the use of contiguous bins does require that the tolerance is immutably fixed to the particular E series. For example, if we are making E24 resistors the bins would need to be +/- 5% in order to be contiguous.
Suppose we want to make a set of E24 resistors with 1% tolerance, as @TimFox describes. This would require the bins to be non-contiguous. Therefore resistors will fall into the gaps.  What to do with those? One thing would be to create a new range of resistors: an E24 2% range, even though that wasn't the original plan. Then some of the leftover resistors will drop into those bins. There are still gaps between the bins, so we now need to create a third range: an E24 5% range. At last, the bins are contiguous and the remaining resistors will all find an appropriate bin.
So, we set out to make an E24 1% range, but in order to not waste resistors we also had to create an E24 2% range and an E24 5% range in order to use up all the resistors. And guess what, we're back to having holes in the distributions for the 2% and 5% resistors.
Another approach making use of the spare resistors is to "promote" them to an E48 1% range, because that has twice as many bins (although still not contiguous) so will catch many of these spare resistors. Unfortunately, every alternate bin will be empty because those values have already ended up in the E24 1% bins. E48 1% bins are still not contiguous, so we can promote the few remaining resistors to E96 1%, where the bins are contiguous and there will be no unassigned resistors.
So, we set out to make an E24 1% range, but this time we had to create an E48 1% range and an E96 1% range to use up those spare resistors. Unfortunately there will be empty E48 and E96 bins because the relevant resistors have already been "stolen" by the E24 binning machine.
Nevertheless, at first glance it looks like the resistors in this promotion-based binning system will have a normal distribution. I think. I need to work on that.
In summary, the original system I described (for each value, widen out the tolerances until all the resistors are assigned) results in non-Gaussian distributions in all the bins apart from the top level bin. The promotion-based system described above, based on @eugene's suggestion and in which resistors are promoted to a higher E series, results in some empty bins in those higher E-series bins, but the occupied bins have a normal distribution.
Phew! This is much more complicated than it first appears.
« Last Edit: May 10, 2025, 12:53:41 pm by SteveThackery »
Online TimFox
« Reply #62 on: May 10, 2025, 02:14:50 pm »
Film resistors for 1% tolerance can be “helixed” during production to within the band, leaving negligible numbers within the dead bands.  Metal foil resistors are usually laser trimmed, with appropriate patterns on the original part to facilitate the trimming.  Similarly, wirewound resistors can be made to tolerance by careful automatic machines.
I once had a conversation with a factory engineer about film capacitors, who said they could adjust the winding machines to achieve the tolerance, without further binning.
Such parts probably are close to a normal (rather than uniform) distribution around their nominal value.
  • 50 year novice
« Reply #63 on: May 10, 2025, 03:21:16 pm »
That's great to know. We've been wondering about whether resistors are made to a certain accuracy, or selected to a certain accuracy.
I've been arguing that if they are tested-and-binned we would usually see non-Gaussian distributions in the bins. If the resistors are made to the required tolerance, then we should expect to see a normal distribution around the nominal value.
Dave's video showed a Gaussian distribution, albeit not reaching out to the tolerance limits. Your information, @TimFox, seems to confirm that resistors are not normally binned. These are the only two bits of information we've got so far, I believe, which just shows how difficult it is to find relevant hard data.  Tim, if you'd said this at the beginning think how much server space we would have saved! 😂🤣
I feel I have flogged this thread to bits, so I'm inclined to stop here (hooray!) and depart knowing that the (limited) evidence so far suggests that accurate resistors are made, not selected. If that turns out to be true, then we can all use RSS with pretty good confidence in the results. I also depart with a tiny suspicion that the most accurate resistors might be really hard to make using the methods @TimFox describes, so are test-and-selected instead. It would seem to make sense. As far as I can see, this could break RSS. I have no evidence to support that suspicion, though.
« Last Edit: May 10, 2025, 03:27:47 pm by SteveThackery »
Online bdunham7
« Reply #64 on: May 10, 2025, 03:54:16 pm »
I would think that given the vast numbers and wide variety of resistors available in the past century or so that almost every method you could imagine has been tried.  Making a 1% film or 2% WW power resistor is likely a much different art than making a selection of carbon composite resistors.  I think it's clear just from what has been presented in that there's ample evidence of this.
The most accurate resistors are test-and-adjusted, usually by laser trimming as TimFox stated.  Some of the most ultra-precision resistor networks appear to be hermetically sealed with a clear side so that they can be laser trimmed after they are packaged.
https://xdevs.com/article/res_f8846a/
Online TimFox
« Reply #65 on: May 10, 2025, 03:54:52 pm »
Among the most accurate resistors are Vishay’s bulk foil planar resistors.
The basic geometry is serpentine on the plane, to reduce inductance, but they can contain regions with specific trim points, so that individual bits can be “blown” in a laser trim after a high resolution resistance measurement in an automated setup.
Vishay Intertechnology published a useful book on resistors Resistor Theory and Technology (2001).  Appendix A discusses these patterns for trimmable foil resistors.  One example (p. 262) shows a pattern that can be trimmed to obtain values between 5 and 1000 Ohms, with 0.5 Ohm steps, by cutting individual lines in a set of coarse and fine path adjustment possibilities.
During my career, I bought semi-custom resistors from Texas Components Corp., who adjust Vishay foil resistor chips to order before packaging them.
Online TimFox
« Reply #66 on: May 10, 2025, 04:04:55 pm »
“RSS” is always true for standard deviations of uncorrelated (statistically independent) random distributions, but “tolerance” vs. “standard deviation” varies depending on the type of distribution (normal, uniform, bimodal, etc.).
Offline iMo
  • Country: li
« Reply #67 on: May 10, 2025, 04:46:45 pm »
Out of my curiosity I've watched several YT videos on the smd resistors manufacturing. From what I've seen they produce the resistors on aprox 10x10cm large ceramic wafers in many steps (pretty complex stuff with several high temperature steps).
They laser trim entire wafer by putting it into a laser machine which cuts an L uniformly into all resistors (for example) with pre-calculated lengths .
My current understanding is they do not measure each resistor during the laser trimming as it would take time.
In one video I saw similar trimming "to given value" where it took aprox 1sec per item with measuring (special precision parts).
There is say 2000 - 10000 resistors (based on size) on the wafer, thus trimming "to given value" while measuring each resistor may take hours.
So my current understanding is they, based on some reference measurement for given resistive paste composition and a test on couple of resistors, trim all resistors with laser without measuring during the trimming, then process them (at least one hot step after the trimming) and (perhaps) they do final binning or just some random sampling.
Would be interesting to know more details about it, indeed..
PS: for example the manufacturing process in steps:
« Last Edit: May 11, 2025, 05:16:04 am by iMo »
  • 50 year novice
« Reply #68 on: May 11, 2025, 09:37:24 am »
OK, so do you think it will produce a meaningful result with the distribution shown below? That is the shape you get from the old-fashioned binning system.
Online gf
« Reply #69 on: May 11, 2025, 11:00:48 am »
Yes, it applies to any distribution if you measure uncertainty in terms of standard deviation.
But if you measure uncertainty as Maximum Absolute Deviation (MAD), then RSS does not apply at all, but MAD(A+B) = MAD(A) + MAD(B). MAD is, however, meaningess for unbounded distributions (like Gaussian and others), since MAD of these distributions is always infinite.
« Last Edit: May 11, 2025, 11:16:30 am by gf »
Online TimFox
« Reply #70 on: May 11, 2025, 02:31:04 pm »
Choose the statistic that is appropriate for your application, to get a statistical estimate that is measurable and meaningful.
Online bdunham7
« Reply #71 on: May 11, 2025, 02:59:47 pm »
Let's say your graph is approximately represented by a set of values (5,5,5,5,5,6,6,6,6,7,7,7,8,8) and their corresponding negative values.  The std dev of that would be 6.35.  The RSS calculation for two same-value resistors in series would give you std dev of about 9.0, or 4.5% if you convert it back into a percentage of the combined resistance.  The combined distribution would fill in the center and would look like a blend of a gaussian curve and a triangle, I'm not sure what you'd call it.  I'm not ambitious enough to calculate it out and graph it.  The 'maximum absolute deviation' would be still be 8% for the combination, although this would occur much less often than in the original batch of single resistors.  Thus combinations of 2S2P, 3S3P and so on would yield combinations that are much more likely to be nearer the nominal value but the 'MAD' would always be 8%.
Is that meaningful?
Edit:  I misinterpreted your graph even though it really is pretty clear.  The numbers I gave assumed that you'd taken out everything up to 5% and the remaining were intended to be 10% tolerance with the extreme values of 9 and 10 also removed.  In this case (2,2,2,2,2,3,3,3,3,4,4,4,5,5) plus the corresponding negative values would be a reasonable representation of your picture.  That gives you a std dev of 3.4 and 2 resistors in series would have a std dev of 4.8 or 2.4% of the combined value, again with a 'MAD' of 10 or 5% of the combined value.  So in the case of one resistor the likelihood of being close to the MAD is high, with two in series it is much more probable the value will be near nominal.
« Last Edit: May 11, 2025, 10:38:28 pm by bdunham7 »
  • 50 year novice
« Reply #72 on: May 11, 2025, 06:02:24 pm »
Is that meaningful?
Thank you - I think it is. 😊
I do need to think it through carefully, though.
