E12 and E24 are two sequences of component values, where E12 is convenient for 10% tolerance and E24 is convenient for 5% tolerance components.
However, it is common (not always done) to see components in a given series with tighter tolerances (e.g., 1%) available as standard products in E24 values.
Ah, dammit, so that puts us back to close to where we were. I think @eugene's proposal is ingenious, but the use of contiguous bins does require that the tolerance is immutably fixed to the particular E series. For example, if we are making E24 resistors the bins would need to be +/- 5% in order to be contiguous.
Suppose we want to make a set of E24 resistors with 1% tolerance, as @TimFox describes. This would require the bins to be non-contiguous. Therefore resistors will fall into the gaps. What to do with those? One thing would be to create a new range of resistors: an E24 2% range, even though that wasn't the original plan. Then some of the leftover resistors will drop into those bins. There are still gaps between the bins, so we now need to create a third range: an E24 5% range. At last, the bins are contiguous and the remaining resistors will all find an appropriate bin.
So, we set out to make an E24 1% range, but in order to not waste resistors we also had to create an E24 2% range and an E24 5% range in order to use up all the resistors. And guess what, we're back to having holes in the distributions for the 2% and 5% resistors.
Another approach making use of the spare resistors is to "promote" them to an E48 1% range, because that has twice as many bins (although still not contiguous) so will catch many of these spare resistors. Unfortunately, every alternate bin will be empty because those values have already ended up in the E24 1% bins. E48 1% bins are still not contiguous, so we can promote the few remaining resistors to E96 1%, where the bins are contiguous and there will be no unassigned resistors.
So, we set out to make an E24 1% range, but this time we had to create an E48 1% range and an E96 1% range to use up those spare resistors. Unfortunately there will be empty E48 and E96 bins because the relevant resistors have already been "stolen" by the E24 binning machine.
Nevertheless, at first glance it looks like the resistors in this promotion-based binning system will have a normal distribution. I think. I need to work on that.
In summary, the original system I described (for each value, widen out the tolerances until all the resistors are assigned) results in non-Gaussian distributions in all the bins apart from the top level bin. The promotion-based system described above, based on @eugene's suggestion and in which resistors are promoted to a higher E series, results in some empty bins in those higher E-series bins, but the occupied bins have a normal distribution.
Phew! This is much more complicated than it first appears.
