1:
I'm currently building a Rubik's cube solving robot out of Legos, with an Arduino uno to run the three motors and to interpret the notation I give it (I'm going to use a website online to calculate the solve).
I'm using a servo, a DC motor and a step motor.
Z_step-motor turns the base (or the whole cube) 90 deg at a time. I am only going to have Z turn one direction for simplicity in the code.
R_DC-motor rotates the whole cube once, on the x axis.
A_servo-motor lifts the arm to enable Z to rotate the entire cube on the Z axis, instead of just the lower slice (in the code 'Au' for arm up and 'Ad' for arm down).
My goal is to use only the Arduino uno kit I have for this robot.
2:
Rubik's cube notation is very common and the most used letters are U, D, R, L, F and B.
To tun a side in reverse a ' is placed after the letter and if you want to rotate the side twice then you add '2' after the letter.
So for this robot a simple U' motion requires the algorithm R R Z Z Z R R
Here is a list of all the algorithms:
U: R R Z R R
U': R R Z Z Z R R
D2: Z Z
R: R R R Z R
R': R Z Z Z R R R
L2: R Z Z R R R
F: Au Z Ad R R R Z R Au Z Z Z Ad
F': Au Z Ad R Z Z Z R R R Au Z Z Z Ad
B2: Au Z Ad R Z Z R R R Au Z Z Z Ad
L: R Z R R R
L’: R Z Z Z R R R
L2: R Z Z R R R
F’: Au Z Ad R R R Z Z Z R Au Z Z Z Ad
F2: Au Z Ad R R R Z Z R Au Z Z Z Ad
B: Au Z Ad R Z R R R Au Z Z Z Ad
B’: Au Z Ad R Z Z Z R R R Au Z Z Z Ad
3:
My first problem is the code and wiring for all three motors.
This is a very rough draft code for test controlling the servo and step motor.
Arduino uses the C++ coding language, which I am not familiar with.
This is my code:
#include <Servo.h>
#include <Stepper.h>
Servo servo;
int x_axis;
int servo_val;
// define number of steps per revolution
#define STEPS 32
// define stepper motor control pins
#define IN1 11
#define IN2 10
#define IN3 9
#define IN4 8
// initialize stepper library
Stepper stepper(STEPS, IN4, IN2, IN3, IN1);
// joystick output is connected to Arduino A1
#define joystick A1
void setup() {
pinMode(A0, INPUT);
servo.attach(13);
void loop() {
x_axis = analogRead(A0);
servo_val = map(x_axis, 0, 1023, 0, 180);
servo.write(servo_val);
// read analog value from the potentiometer
int val = analogRead(joystick);
// if the joystic is in the middle ===> stop the motor
if ((val > 500) && (val < 523)) {
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, LOW);
else {
// move the motor in the first direction
if (val >= 523) {
// map the speed between 5 and 500 rpm
int speed_ = map(val, 523, 1023, 5, 1000);
// set motor speed
stepper.setSpeed(speed_);
// move the motor (1 step)
stepper.step(1);
// move the motor in the other direction
if (val <= 500) {
int speed_ = map(val, 500, 0, 5, 1000);
// set motor speed
stepper.step(-1);
}and here is the DC motor test code:
#define E1 5 // Enable Pin for motor
#define I1 3 // Control pin 1 for motor
#define I2 4 // Control pin 2 for motor
void setup() {
pinMode(E1, OUTPUT);
pinMode(I1, OUTPUT);
pinMode(I2, OUTPUT);
void loop() {
analogWrite(E1, 255);
digitalWrite(I1, HIGH);
delay(3000);
digitalWrite(E1, LOW);
delay(2000);
}Any input, Ideas, hints or help would be much appreciated, especially with the code.
