Author Topic: Schematic help - contact sense  (Read 1971 times)
Offline anishkgtTopic starter
  • Country: qa
    • George Hobby
« on: November 15, 2018, 10:01:50 am »
Hello All,
I am trying to sense when two electrodes makes a contact. I've put up a schematic, partially completed. How can i trigger the T1 when the electrodes the short.
Would appreciate if any one could help or suggest me a better option.
Offline JVR
Re: Schematic help - contact sense
« Reply #1 on: November 15, 2018, 10:25:30 am »
How about telling us what the contacts are, and where they are used. Since that schematic looks like overkill, unless some context and constraints are elaborated upon.
  • Country: qa
    • George Hobby
« Reply #2 on: November 15, 2018, 10:29:26 am »
Oh sorry, it’s spot welder. When triggered the electrodes have 2vac at the electrodes and several amps to spot weld nickel strips to 18650 cells.
Www.Georgehobby.wordpress.com
Equipments: DSO104z, Hakko FX888D, Brymen BM869s
Sent from my iPhone using Tapatalk
Offline JVR
« Reply #3 on: November 15, 2018, 03:16:45 pm »
I'd suggest a current sense method, as I assume open circuit the voltage will be higher.
  • Country: qa
    • George Hobby
« Reply #4 on: November 15, 2018, 04:52:22 pm »
2vac is actually the open circuit voltage.
Yes sounds like a better idea to sense the current.  So how many ohms resistor should I go with ? Through hole or smd ?
The resistor would go in parallel with one of the cable and two wires form both sides of the resistor the add of the muc, correct ? Would it be a good idea to sense the current during the weld also ?
Offline JVR
« Reply #5 on: November 16, 2018, 08:33:13 am »
Here is a complete thread about the development of a spot welder: https://www.eevblog.com/forum/projects/guesses-on-what-i-am-attempting-here/
I would sense the current using a hall effect chip, any resistance you add will sap energy away from the weld
