Are those pdfs showing just an image? Use the forums image handling to make it easier to view/quote/comment on.
The reason I did PDFs (ignoring that my scope either prints to a default virtual PDF printer or saves as an image) is that it includes all the scope settings allowing anyone deciphering the waveform to see exactly how the scope was setup.
I had similar problems when using my signal generator, an FY6600, with its original power supply, it was generating up to 80V AC on its -ve terminal wrt ground on the scope. I had to upgrade the PSU in the unit to eliminate the noise, now it's just fine.
I didn't consider noise from the generator, however, recently I measured a full wave circuit in a stereo amp going through a diff probe, had a good ground connection, etc... and got the typical noise (see attached).
I don't remember if I had scaled the v/div correctly in the attachment because I was going through the diff probe, but I was paying more attention to how the waveform looked.
As mentioned, I'm so use to low grade scopes that produce somewhat pencil thick waveforms that using this higher end model raises questions on what I'm doing wrong. Since all four channels and two same model scopes produce similar looking waveforms, I somewhat ruled out a broken scope.
Typically triggering issues in one case may be not using another channel to trigger on a data bus, then another time it's that I triggered correctly, but then the wave decides to jump phase for some reason, now it was changing the sample mode to high resolution gave me a waveform I am familiar with.
Seems I haven't provided enough information, so let me take more measurements maybe this weekend and I'll post them. It's probably easier to examine this question with the scope present rather than a single image, so I understand the difficulty in assessing the images.
