Author Topic: Selecting low power monolithic boost controller  (Read 680 times)
Offline makebitTopic starter
  • Regular Restricted
« on: October 02, 2025, 08:41:44 pm »
Muggins here agreed to get a PCB done for tomorrow,
But didnt realise how long it would take to find a low power monolithic boost controller IC.
All we need is vin 2v7 to 10V, Vout = 5V, iout = <20mA.
But the ti.com search engine just crashes every time i try and sort by a column.
I know ti.com are the best for this, does anyone know a part number off the top of their head?
Hi, I'm also known as Treez, Faringdon, 5ubtle, ocset, zenerbjt opampsmoker, and coffeefet. I've been a naughty boy, so I'm not allowed to start new threads any more.
I'm also not allowed to change this footer :-(
Offline langwadt
Re: Selecting low power monolithic boost controller
« Reply #1 on: October 02, 2025, 08:44:29 pm »
for Vout < Vin a regular boost won't do
The following users thanked this post: makebit
« Reply #2 on: October 02, 2025, 08:58:33 pm »
Thanks, yes, vout will always be > vin....we want "vin_withstand" to be high enough so that sudden vin connection doesnt "LC ring up" and blow the input voltage pin.
So Vin could be 4.3v and sudden, so anything up to 10v input withstand is preferred.
As discussed, the ti.com search engine is crashing, so we are just going through one by one.....and so far, LM27313 is the lowest power with an 800mA switch current limit...but i am sure there is lower than that.
I always used to use a richtek one with a 20ma current limit, but it must now be  obselete.
Offline langwadt
« Reply #3 on: October 02, 2025, 09:11:14 pm »
but if Vin is 10V so is Vout
Offline PCB.Wiz
« Reply #4 on: October 02, 2025, 09:46:22 pm »
20mA has been competed out of the market.
TI says this about LM27313
A newer version of this product is available: Pin-for-pin with same functionality to the compared device
TLV61047  NEW ACTIVE
20VIN, 28VOUT, 2.2A non-synchronous boost converter with SOT23-5 DDC package Wider input voltage and higher efficiency.    Iq (typ) (µA)   25
Addit : over at lcsc this may be an alternative  Quiescent Current   100uA  Operating Voltage   2.2V~16V
https://www.lcsc.com/product-detail/C2974847.html
and slightly lower indicated Iq  Quiescent Current   50uA    Operating Voltage 2V~24V
https://www.lcsc.com/product-detail/C5123435.html
« Last Edit: October 02, 2025, 10:51:26 pm by PCB.Wiz »
