I don't know for sure, but you sure haven't made it easy to figure out...
(In the reactions that follow, imagine a cartoon acting it out. I like to overreact.
But first of all: please don't post incomplete schematics and pictures.
If you want easy answers, don't make it hard to find those answers!
Or, if you're shy about IP, there are many here willing to do a quick review-for-hire, or more. (I have a few spare hours knocking around, myself!
And the PCB drawings -- can you show silkscreen, soldermask and copper in the same view? Whole board, or at least whole power section. I'm constantly flipping between four tabs here, and the 3D view doesn't even cover the power area.
And describe, in detail, your load, source, operating conditions / setpoint, and so on.
Does it get hot just sitting there at no load, or is this full throttle (or more)? We don't know what you're trying to do with it.
Onward!
1. There are miles between components.
Q2 connects on big long traces. C2 is way off to the side. Where even is C19?
Why is there another MOSFET (probably) in series with the diode? Why isn't this shown in the 3D picture (it's off to the right)?
What's C14? It looks big and important and nearby, but the top copper looks like it's not connected to the power area. I guess.
The current shunt resistors wrap around Q2 and are way out of the way. Wait, no, that's VCC to C13 and C16, but the shunts are still way off.
Also, Q1's 3D model doesn't look well positioned, oh and U3. Buh...
2. Ground. It's really bad.
You have top and bottom pours, that's a good start -- but the distance between where it's needed, and where it connects, is huge (like from Q2 drain via shunt resistors).
And it's full of holes: you've negated the whole bottom layer by chopping it up with routing traces. Run those WAY around the power section.
Then stitch it up with tons of vias. You should probably have 200 vias or more in a design this size. Over half will be ground vias!
Oh, oh no.
Oh no.
I've just realized, the top side isn't ground. It's 5V. You don't even have the possibility for a single stitched ground. The mere presence of the top fill is
making the power section worse.
If it had been ground, at least you'd have a couple shorter grounds, but this is just... the current flow paths are labyrinthine!
3. No hooks for playing with EMI.
By that, I mean stuff like:
- Series gate drive resistor to Q2 (or ferrite bead, or resistor and diode, or whatever)
- R+C network across Q2 and D7
- More locations (also, closer locations) for optional bypass caps
- Extra LC filtering at input, output
Oh, oh no. I just realized GNDPWR is separate from GND, like, that it's separate at all is one thing -- but also that it's only tied, through the chip internally, and through two series capacitors. You could plug in a battery wrong, explode the chip and a few resistors, and have the whole thing just flapping in the rain, no connection between in and out. You don't want that as a failure mode. You want fuses to handle that.
It's maybe a little shocking that the chip didn't melt itself from the EMI [yet?].
So add that, too: the input and output are quasi-isolated, except not really, so each GND pin and each power pin needs to be filtered with respect to circuit ground. As is, it's a two-ended radiotransmitter!
4. Thermal.
95C might well be a perfectly reasonable design operating temperature; what did you design for?
Only a teeny trace on Q2 drain. No heatsinking to spread out the heat. (That said, the top and bottom pours
do help a little with this.)
There's not much to do with inductors. Semiconductors are worth having big fat pads/pours on. Resistors too. Capacitors shouldn't get hot, but you want big fat conductors on them, too.
So, where to go?
I'm guessing you're pretty new to layout, at least this kind of layout.
First, rip everything up.
If it seems like a lot of work, that's all the more reason to do so -- rip it up ten times over, and gain experience with your tools, with the circuit. By the tenth time, you'll be ten times faster. (An experienced layouter would do this board in maybe a day or two.)
Get rid of GNDPWR. Use GND for all inputs, outputs and signals.
Rebuild it with a solid ground plane on the bottom, and ground pour on top. Use bottom routing as sparingly as possible. (Example: if two traces must cross, then near the crossing, use two vias and a short segment on the bottom side. This keeps the negative space around that trace as short as the segment. Then stitch around the top side ground with vias.)
Pack the components as close as you can. Minimize distance between R22/R24, Q2, L1 pins 3 and 4, C18, D7 and C19. That exact string of components is your switching loop. Add up the perimeter length. It should be no problem to have it around, oh, a half an inch, maybe less. You've probably got, hmm, three or four inches there? It's a huge difference.
Keep C13, C16 and R28/R30 nearby. That's a no-brainer since they're right at the ass end of L1.
Add a resistor in series with Q2 gate. Maybe 10 ohms. Not much, but a starting point. Try more, try less; try a diode in parallel (either direction), try a ferrite bead. The driver doesn't look to be too strong,
Oh, and don't go ham on the transistor or diode ratings. You don't want minimum conduction losses, you need low switching losses too. Looks like IRF7807 is pretty reasonable for a couple of amps, and not extreme on gate charge (17nC at 5V is 3.4nF equivalent; a 10 ohm driver will commutate this in about 70ns). Good choice, and B330A. (Though to be honest, it's hard to screw up schottky diodes, as long as the voltage and current ratings are appropriate. Outside of those basic options, there's very little freedom in schottky diodes -- voltage rating and voltage drop / leakage are a straight tradeoff. It's not like transistors where there's a whole spectrum of old and new parts, with different options, companions (transistor pairs, internal diodes..), and materials (GaN, SiC, Si).)
It may also be worth having an R+C across C18, because its voltage can oscillate. C18 resonates with L1's leakage inductance, and this resonant tank is in series between input and output, which can do weird things for your current sense (R28/R30), input and output ripple, and controller.
All of these values, by the way, can either be calculated directly, or at least hand-wavingly estimated. I'm not going to drown you in equations, but take comfort that they exist.
Cheers,
