Groan-worthy puns? What, are you trying to be
me now? That's
my job!
By the way, PCB is from Elecrow. Thought I'd give them a try. Not quite as nice as ITead - the silkscreen is smudged in a couple places, the HASL isn't quite L* (this was actually enough to be a bit of an annoyance with the TSSOPs, I imagine it could be a bear with lots of fine-pitched packages and reflow soldering), and the silkscreen registration is off a bit. It just looks kind of cheap, at least up close. One of the boards actually had a solder lump hanging off one of the pads. But electrically, everything is just fine, nothing questionable in the copper and the drill registration is spot on.
*I just picked up another one and looked a bit more closely. The HASL finish is perfect on one side, and lumpy on the other. On the lumpy side, the pads rise above the solder mask, so that when you're placing a chip, it tends to fall with its pins in between the pads. There's probably enough stuck to the pads to solder many components with just a bit of flux - I'm not really convinced the hot air ever touched that side... The lumpy side is not consistent, I have about half with smooth top and half with smooth bottom.
