Author Topic: Simulating Complex Loads  (Read 4146 times)
Offline Evan.CornellTopic starter
« on: January 27, 2018, 04:46:30 pm »
If I have data describing a complex impedance (say, 100 data-points of magnitude & phase at various frequencies) collected from a RLC / impedance analyzer, is it possible to insert that into simulation program for analysis in a larger system?
I am currently familiar with TINA-TI, so being able to use that program would be ideal, but if anyone knows how to do such a thing in other (preferably free) tools, that would be extremely helpful.
Offline Nitrousoxide
Re: Simulating Complex Loads
« Reply #1 on: January 29, 2018, 06:02:09 am »
If you have the frequency response (or time domain response) from the network, you can then use multiple methods to generate a transfer function in the laplace domain (s-plane).
A common method is design by bode plot, where the magnitude and phase response is observed and a transfer function is generated usually in zero, pole and gain form.
Once a transfer function is determined, it can be realised by either passive or active networks. A good example of this is a pure-integrator implementation.
If you're looking for a specific process, here is a good example with matlab: http://au.mathworks.com/help/ident/examples/frequency-domain-identification-estimating-models-using-frequency-domain-data.html?prodcode=ID&language=en
How complicated is the bode plot? (how many poles and zeros?)
« Last Edit: January 29, 2018, 06:04:51 am by Nitrousoxide »
« Reply #2 on: January 29, 2018, 01:03:37 pm »
To add some more information, I have found out that TINA-Industrial is required to directly take impedance measurements into simulations. So, for free simulators, it does look like fitting the data to a lumped-element model is the best method for simulation.
See screenshot attached for shape of impedance data that I need to model.
« Reply #3 on: January 29, 2018, 01:47:57 pm »
Would you be willing to share the data in CSV format? I would gladly have a go at modelling the transfer function.
« Reply #4 on: January 29, 2018, 01:55:21 pm »
Please find attached. I would be most grateful if you could share your process for fitting model to the data, as I'm going to have to repeat this process in the future..
Thanks,
Evan
« Reply #5 on: January 29, 2018, 02:55:17 pm »
Awesome, I will give it a show tomorrow morning as it is 2AM and brain no function  |O
One thing that I glossed over is to mention 2 port network parameters and how they are essential if you want to correctly model/analyse a system.
I'm going to assume that the data given is the Z11 parameter (i.e. the impedance "looking into" the input). (and before people yell at me, im approximating Zin = Z11, bad i know)
This is the case for a passive network with a single input, I am assuming this as the vertical axis in your plot has the unit of ohms.
« Last Edit: January 29, 2018, 02:57:44 pm by Nitrousoxide »
« Reply #6 on: January 29, 2018, 02:57:05 pm »
This data was taken by hooking up the test leads of B&K 891 RLC meter to the two leads of the device under test, and getting impedance magnitude data (in ohms) and impedance phase data (in degrees).
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: January 29, 2018, 07:59:07 pm »
Keep in mind that the impedance will vary greatly with what's on the other side of that... piezo transducer, if I had to guess. :)
Indeed it doesn't seem to be all that well matched, for how strong the main resonance is, and it also seems to be in a bit of a cavity, given the higher modes (not quite harmonics).  Pretty typical for air, I suppose.
The equivalent circuit will be, more or less: a capacitor (the terminal capacitance of the device), with branches in parallel.  Each branch is a series RLC, resonant at whatever frequency.  This should give you enough info to start playing around.  Though it's not all that easy to adjust; that's why I wrote this:
https://www.seventransistorlabs.com/Calc/Filter1~.html
(Hover over the schematic elements to view tooltips, transform, change, add or remove stages.  Set unused components to near-zero or near-infinite.  Click and drag values to adjust in real time.)
Seven Transistor Labs, LLC
Online nctnico
« Reply #8 on: January 30, 2018, 12:36:56 am »
The last time I played with piezo transducers I used a lumped model and calculated the values by using the characteristics from the datasheet. There is a lot of good info out there on how to do this. See the attached PDF.
The following users thanked this post: Evan.Cornell
« Reply #9 on: April 03, 2018, 03:51:09 pm »
So a single RLC || C model (Butterworth VanDyke) doesn't really capture the phase information properly in the frequency region I care about (25-35kHz).
So I am back to wondering if there are any SPICE tools that can take in a list of impedance data points to run AC sweeps. Any ideas?
Offline rstofer
« Reply #10 on: April 03, 2018, 04:48:44 pm »
I guess I would use LTspice.  If I wanted to find out if it can be done, I would join the Yahoo LTspice group because there are some VERY knowledgeable people over there.  Be aware that there are two LTspice groups on Yahoo.  One is a user forum and the other is a repository for files.
Offline Bud
« Reply #11 on: April 03, 2018, 06:02:48 pm »
Many simulation programs have an ability to load and use S-parameters files. They would have a S-parameter component, you load your S-parameters file in it and use the block as any other component to set up an analysis. Look for such component in your favorite simulation program.
« Reply #12 on: April 03, 2018, 07:48:29 pm »
I have a list of impedance values (polar or rectangular format possible) taken at various frequencies. How would I go about converting this into s-parameter file?
Offline Bud
« Reply #13 on: April 03, 2018, 08:25:31 pm »
Look for Touchstone file format, there are different data representations that can be used to create a file out of your data.
« Reply #14 on: April 04, 2018, 07:37:38 pm »
Any free SPICE simulators that can read in touchstone files and do AC sweeps?
Offline Marco
« Reply #15 on: April 04, 2018, 08:17:27 pm »
Can't B-sources do this with LTSPICE?
