I'm developing a push-pull SMPS power supply, 12VDC to 180VDC, and my power target is 500W. The design of the rest of the system is all fine and good, but when it comes to actually building the transformer, I'm at a loss of how to proceed.
I purchased a core and bobbin as per my design, and the design also calls for a 20mil copper foil, 6 turns center-tapped. My problem is that this is proving to be quite cumbersome, the first issue being attaching wires to the foil that are large enough to carry the requisite current, but also fit within the bobbin and can be soldered to the legs. Then I thought why not just cut some copper tabs, and have them exposed and wired directly to board. However this is all bringing up a question I've been having, which is, should I temper my expectations with regard to the kind of power I will be able to get out of a home-constructed transformer? I would love to have one made (or find one with the right turns ratio, inductance, etc) but I already got two "thanks, no thanks" replies from Coilcraft and someone else, my project is probably too small for them to want to bother with. So that leaves me stuck either re-designing for smaller power loads, or trying something else entirely. But I've seen people build much larger transformers successfully, I just can't seem to find much practical information out there with my specific situation.
I guess what I'm asking for is practical advice for building these things. How would the pros tackle something like this? My eventual goal is to be a power electronics engineer so this is above all a learning experience. Additionally, are there small shops out there that someone can recommend who would build something like this for me?
Thanks!
