Author Topic: Socket pins  (Read 3150 times)
Offline AccelMotionTopic starter
Socket pins
« on: August 25, 2015, 05:45:09 pm »
I'm looking for something, and can't find it.
It's a machine-pin socket strip, female on top and round pins on the bottom. It accepts .025" square pins on the female socket header part, up to a .2" depth or so.
Has anyone any idea what these pin strips are called and how to find more? My searches always yield the expected socket strips that accept IC pins, but not .025" square (wirewrap) pins.
Any thoughts about where to look?
Offline edpalmer42
Re: Socket pins
« Reply #1 on: August 25, 2015, 06:15:10 pm »
Keystone makes things like that.  Most of the big distributors carry the brand.  You'll have to check to see if they have that item.
http://www.keyelco.com/
Ed
Offline w2aew
    • My YouTube Channel
Re: Socket pins
« Reply #2 on: August 26, 2015, 03:05:13 am »
Also check Mill-Max, they make all sorts of pin sockets.
FAE for Tektronix
Re: Socket pins
« Reply #3 on: September 01, 2015, 07:52:36 pm »
Lots of folks make sockets. I'm looking for a female machine-pin socket strip that would accept a .025"square pin..   :(
Offline Monkeh
Re: Socket pins
« Reply #4 on: September 01, 2015, 08:07:23 pm »
https://www.mill-max.com/products/socket/801-XX-XXX-10-003000
Series 801 and 803 receptacles use Hi-Rel,
6-fi nger BeCu #16 contact rated at 4.5 amps.
Receptacles accept .025” diameter and .025”
square pins.
Re: Socket pins
« Reply #5 on: September 02, 2015, 06:08:59 pm »
Thanks to everyone for help. The Mill-Max is an appropriate choice, but very expensive.
Whatever we used to buy was much less expensive, but I just can't identify it.
Offline fivefish
Re: Socket pins
« Reply #6 on: September 02, 2015, 06:11:20 pm »
The new Rohs compliant Mill Max are more expensive than the old non-Rohs millmax.
3x more expensive on one particular model I'm using.
