Author Topic: Strategy for reverse engineering a simple PCB  (Read 1418 times)
Offline NivagSwerdnaTopic starter
« on: December 22, 2018, 06:11:14 pm »
Please see attached image
I would like to draw a schematic for the following PCB (I also have a scan for the bottom layer)...
It is a simple 2 layer board from the 1980s which replaces some custom Konami silicon which is now unobtainium
Are there any tools that allow me to draw a PCB but then go backwards to the schematic?
Thanks in advance
Online helius
Re: Strategy for reverse engineering a simple PCB
« Reply #1 on: December 22, 2018, 06:24:54 pm »
More seriously, I think some EDA programs do have the ability to link layout and schematic editors, but they are not designed to be used to infer a schematic from a layout.
Offline soldar
« Reply #2 on: December 22, 2018, 07:51:41 pm »
I have successfully done this by taking photos or scans of both sides and then working with them with a graphics program like Photoshop but you still have to do a lot of manual work confirming paths, connections, etc. It is very time consuming but it can be done.
Offline amyk
« Reply #3 on: December 22, 2018, 07:55:45 pm »
Post both sides, someone may help. ;)
What I do is put the parts in the same relative position in a schematic editor, then draw the traces in the same way.
Besides the top left component (which appears to have been sanded), everything else there looks like standard TTL.
« Reply #4 on: December 22, 2018, 08:04:07 pm »
Thanks.  Maybe DaveCAD is a good approach.
The circuit should be logically divided into three... but I haven't worked out the detail yet
