Author Topic: TeensyLCR – A Teensy based DIY LCR Meter  (Read 78820 times)
Offline HaiLun
  • Country: hk
Re: TeensyLCR – A Teensy based DIY LCR Meter
« Reply #50 on: January 24, 2025, 12:49:49 am »
Very nice project.
I'd like to add a good transistor hFE tester to this.  Something that could test with base current > 1.0 uA, VCE > 1 volt and read betas higher than ~600.  These are the parameters of most of the current transistor testers.
It would be great if it had a thermistor attached to the transistor and it measured hFE at different temperatures as the transistor heated up.
VCE > 1   ………… Are you sure 1V is enough?
Offline drksy
« Reply #51 on: January 24, 2025, 02:24:10 am »
What's the total cost to build one from scratch, only counting the electronics, no enclosure, no kelvin alligators or other mechanical/misc stuff?
Offline WeTecTopic starter
« Reply #52 on: January 24, 2025, 02:13:41 pm »
I had the idea to add a DC output like Agilent E4980A option 001. This can also be used to measure RDSon of MOSFETs. A DAC module could easely be implemented. I had this in mind: DFRobot GP8211 1-Channel 15-bit I2C to 0-5V/10V DAC Module (https://www.dfrobot.com/product-2753.html).
« Reply #53 on: January 24, 2025, 04:43:41 pm »
  • PCB with most of the passives preassembled: 80$ (incl. shipping+taxes) for 5 pcs.
  • Display: 10$
  • Teensy 4.1: 32$ (was a christmas pressent, so 0$ for me)
  • Most of the ICs where salvaged from other PCBs or samples. So 0$ for me. About 87$ at Digikey for 1 unit.
  • BNC connectors: 16$ (Salvaged from other PCBs, so 0$ for me.)
  • Cheapo 4x4 keypad: 1$. I used a selfmade keyboard PCB: 7$ for 5 pcs.
  • rotary encoder: 2$
I paid about 100$. In addition to the fun of building it, it was absolutely worth it. If you are going to build it from scratch it will cost about 235$ + additional cost for kelvin alligators clips and other stuff. Depends what is laying around and in the junk box.  ;D
The following users thanked this post: drksy
« Reply #54 on: March 02, 2025, 06:00:49 pm »
Some improvements have been made:
  • Frequency resolution is now 10 Hz (was 100 Hz).
  • Minimum frequency is now 10 Hz (was 100 Hz). Now one can measure components at mains frequencies like 50/60/100/120 Hz.
  • Added list sweep function. Perform automatic sweep measurement by sweeping the frequency linearly or logarithmically. Users can view data by a table and obtain up to 100 points in one sweep. If a USB flash drive is connected, sweep data is stored as text file automatically.
  • OPEN and SHORT correction function performs correction over 38 pre-set frequencies. The correction for all other frequencies are interpolated from those pre-set frequencies. The correction data is stored permanently on the EEPROM.
Offline elwar85
« Reply #55 on: March 23, 2025, 09:50:57 pm »
Very cool project. I'm interested in building one of these but would like to make some adjustments to the PCB form factor (to fit into a specific handheld enclosure). I gather it was designed in EasyEDA. Would you consider adding the schematic/PCB files to the repo?
« Reply #56 on: March 24, 2025, 04:48:01 pm »
Schematic and Gerber files are on Github already. Recently I made some adjustments to the built-in calibration routine and the hardware (tuning some resistor values). The repo is not up to date yet. I'll keep you updated.
Offline elwar85
« Reply #57 on: March 24, 2025, 06:53:06 pm »
I've seen there's a PDF of the schematic and the Gerber files, but this doesn't let me make changes to the layout. I'd have to rebuild both in EasyEDA to be able to change the PCB dimensions and move things around a bit. Was just hoping you might be able to save me that job!
Will await your update before I attempt a build anyway, if there's been hardware changes.
« Last Edit: March 24, 2025, 06:54:43 pm by elwar85 »
Online coromonadalix
« Reply #58 on: April 16, 2025, 12:27:56 pm »
@elwar85   you're still lucky to have source code and schematics ....
What would be the Teensy minimal board revision(s)  the latest 4.1  that i would need to buy     or some older 3.5 3.6 ? i have one of theses laying somewhere
thks and continue the work    :-+
« Reply #59 on: May 04, 2025, 04:30:39 pm »
Recently I've updated the calibration routine. Everything you need is a pretty good AC voltmeter with 1VAC range (I recommend to use 34461A ;D) and a couple of 0.1% resistors. You first adjust the output with the AC voltmeter. Voltage and current ranges are adjusted by using 0.1% precission resistors and the output. I achieved good accuracy after the adjustment. The reading error is less than 0.5% of all 0.1% resistors I have. Detailed results will follow.
In order to achieve higher output voltage levels, changes are made to the output and input filters. Check Github for the latest schematic. Output level can now be set between 0.03 Vrms and 2.5 Vrms with 1 mV resolution.
« Reply #60 on: May 04, 2025, 04:36:29 pm »
I recommend to use Teensy 4.1 because of way more CPU speed. I do a lot of calculations every 200ms. The floating point unit helps alot, but I'm not sure if the older models are fast enough.
The following users thanked this post: coromonadalix
« Reply #61 on: May 27, 2025, 06:04:50 pm »
You don't actually need a voltmeter like the 34461A for adjustment. Your regular handheld multimeter from the drawer is sufficient to adjust the output voltage of the LCR meter. The input voltage and current ranges are adjusted by applying a voltage to the 0.1% resistors. So the error of the voltmeter is equal (and with same sign) on the voltage and current measurement. The error is compensated by applying Ohm's law.
I used my Extech EX330 to adjust the output. The EX330 has an accuracy of 1.5 %+-3 digit at the 4VAC range.
I did some measurements with 0.1% resistors from 100 Ohm to 1 MOhm @100 Hz, 1 kHz and 10 kHz test frequency. For this purpose I built four resistance decade boxes with 0.1% resistors (one decade per box, 100 Ohm, 1k, 10k and 100k).
100 Hz: Rs error of all results (100Ohm - 1MOhm) is <= 0.1%.
1 kHz: Rs error of measurements up to 600 kOhm is <= 0.1%. From 700 kOhm, the error increases to -0.25% at 1 MOhm.
10 kHz: Rs error of measurements up to 90 kOhm is <= 0.1%. From 100 kOhm, the error increases to -8% at 1 MOhm.
« Reply #62 on: May 27, 2025, 06:38:28 pm »
I still have some issues to get precise results of the phase between voltage and current. Especially at test frequencies >10kHz and very low or very high impedances. The main reason is the phase error of the gain stages. A phase measurement with an oscilloscope (probe before and after the gain stage) confirmed the simulation.
« Reply #63 on: July 06, 2025, 01:57:21 pm »
In fact, the parasitic capacities are way more complex than shown in the image above. For instance, there are some additional capacities at the analog switch. Hard to simulate. However, I have determained some phase correction values by measuring the phase of resistors (where I assumed no reactance). I use this values to compensate the phase deviation over frequency and gain setting. The overall phase error is not perfect but good enough to make some considerations about accuracy. I have created an accuracy chart which shows the impedance accuracy over frequency. This is based on resistor measurements only, but I assume that capacity and inductance results ar not far from that. Furthermore, I decided to specify only up to 80 kHz. 90 kHz is possible but, well, not very precice.
Offline viveksingh
  • Country: in
« Reply #64 on: September 23, 2026, 11:36:30 am »
Can you share some video or working of this project (TeensyLCR meter)?
« Reply #65 on: October 04, 2026, 02:53:19 pm »
Sorry, I don't have sufficient video equipment for recording. Working is very similar to use a regular DMM. The device is ready for measurement a second after power up. Default settings after power up are
  • Function: Cs/Rs
  • Level: 1 Vrms
  • Frequency: 1 kHz
Just connect your DUT and results are displayed. Changing settings is easy via touch menu. Values can be entered via keypad.
Offline rickjf
    • eCircuit Center
« Reply #66 on: October 07, 2026, 07:48:59 pm »
Excellent project! Measuring down to small capacitances is impressive.
To help me understand LCR meters, I put together a very basic LTSPICE file. The TI Note you listed provided some key insights.
2946257-0
For the Z calculations, I applied the equations from the Keysight Impedance Measurement Handbook (see attached PDF).
2946261-1
The waveforms tell a nice story - viewing from bottom up, the signals move left to right across the schematic - really helped me understand the operation.
2946265-2
Was fun to test the meter with a capacitor at 1kHz. A measured reactance of X=-159 verifed the cap under test C=-1/(2*pi*f*X)=1uF.
Attached is the zip file of the LTSPICE .asc, .plt and an Excel file.
My next step is to replace the ideal amplifier models with more realistic ones.
The following users thanked this post: WeTec
Offline MisterHeadache
    • Level UP EE Lab
« Reply #67 on: October 07, 2026, 08:24:13 pm »
Very nice project!
Any data to share on measuring inductors?  Especially those in the 10nH to 100uH range?  My apologies if I missed that data, I searched the 3 pages and couldn't see any.
Daryn from Level Up EE Lab
AKA 'MisterHeadache'
Offline mawyatt
« Reply #68 on: October 07, 2026, 08:38:19 pm »
Small capacitances at low frequencies produce little device current. Small inductors impose a different issue as they represent a small impedance at low frequencies and produce large DUT currents.
For example, 1pf at 1kHz produces just ~6.3na with 1Vrms excitation, while a 1nH at 1kHz produces just ~6.3uΩ impedance and thus requires high test currents.
Measuring small capacitances at higher frequencies and test voltage helps improve results, same for small inductors with higher frequencies and higher test currents.
Best
~Wyatt Labs by Mike~
    • Level UP EE Lab
« Reply #69 on: October 08, 2026, 07:15:20 pm »
Best
Right, I see that now.  10nH even at the max usable frequency of 80kHz would only be 0.005 Ohms inductive reactance.  So let me modify the lower range in my question - how about data measuring inductors from 1uH to 100uH?
1uH measured at 80kHz would be 0.5 Ohms, and is right on the boundary of the 2% error window on the chart.
100uH measured at 10kHz would be 6.2 Ohms, right at the 0.5% to 2% error window boundary on the chart.
So that range of inductance seems to be within the specs.
I'm curious because I am investigating building one, because most of my usage would be measuring inductors not capacitors or resistors.  My present method mostly uses the W2AEW method of a fast edge pulse generator / resonant circuit / oscilloscope, which works but is more manually intensive.
« Reply #70 on: October 10, 2026, 03:56:25 pm »
I did some measurements on a 47uH wire wound shielded inductor (TDK VLF3012AT-470MR22) using the sweep function. Here are the results:
Quite noisy below 500 Hz. As mawyatt mentioned above, the impedance reactance there is very low.
This chart illustrates the relationship between resistance, reactance, and impedance. At low frequencies, the ohmic resistance (Rs) of the copper winding outweighs the reactance of the inductor (jX). The complex sum of the resistance Rs and the reactance X is the impedance Z.
TDK provides good specification data for this part. The data I measured are comparable.
https://product.tdk.com/de/search/inductor/inductor/smd/info?part_no=VLF3012AT-470MR22
« Last Edit: October 10, 2026, 07:45:47 pm by WeTec »
The following users thanked this post: MisterHeadache
« Reply #71 on: October 10, 2026, 04:07:03 pm »
It is a small part so I used my SMD test fixture (thanks mawyatt for sharing the PCB data  :) ).
2949101-0
I used a metal case from an old network switch, some BNC connectors from ebay (with teflon insulation, not the cheapest ones) and 3D printed levers.
2949105-1
Quite handy  8)
The following users thanked this post: mawyatt, MisterHeadache
« Reply #72 on: October 10, 2026, 04:25:31 pm »
I was able to perform a DC bias measurement using the following test circuit:
I used the primary side of a transformer as series inductance L (>4H) and a big chunky 22mF capacitor. The results are also comparable to the manufacturer specifications:
Edit: fixed typo in the measurement data
« Last Edit: October 10, 2026, 07:05:33 pm by WeTec »
The following users thanked this post: Roehrenonkel, MisterHeadache
Offline mawyatt
« Reply #73 on: October 11, 2026, 12:32:37 am »
(Attachment Link)
(Attachment Link)
Quite handy  8)
That fixture looks really good, ready to see it measure some 2512 10mΩ 0.1% resistors :-+
Looks as if you've "roughened" up the PCB SMD contact surface some!!
This fixture just works for us (and others), and good to see another using such.
Your Teensy LCR meter is quite nice, well done  :clap:
Best
« Reply #74 on: October 11, 2026, 09:32:41 am »
Thanks. 10mΩ is out of my measurement range but if I got one of a resistor with that value I will measure it  :)
For the inductance measurement above, I used a 2 V excitation voltage. The idea behind this was to minimize noise in order to obtain more accurate measurements. In fact, I achieved the opposite. Due to core nonlinearity, satturation effects and losses within the ferrite core one can observe different measurement results depending on excitation voltage. Here are some results of the same DUT with different excitation voltages:
At the moment, I can't explain the decrease in inductance above 30 kHz. Maybe insufficient compensation...
