I can see both points - but some places run rigid test schemes, where every node needs a test point, and your resistors, while sane, don't do the necessary - in fact, they add test points.
Are you sure that the test regime doesn't do a quick squawk between all nodes designated power before starting, to rule out power-ground and power-power shorts? With hundreds of tiny decouplers on even a small board, it's a reasonably common failure mode.
My short answer: do what makes your test house happy (as long as it's not truly insane). They've got a workflow which (one hopes) works for them...
