Hmmmm 20kVp to 110kVp spec. Again, this is unusual / meaningless terminology with respect to the energy levels to which the camera is exposed. 110kVp does not produce 110kev as the conversion to X-Ray energy is anything but efficient. Tube specs must surely affect the output energy for a stated excitation voltage and tube current. Oh well, provided you stay under 110kVp I suppose Hamamatsu are confident their array will operate correctly.
As you say, a nice camera, but they are darned expensive. When reading about the Hamamatsu camera, I was impressed to read that the scintillator is a direct deposit on the photo detectors rather than a separate scintillator sheet, as found in the BIOPTICS camera. Direct deposition of scintillator material on the detector element produces the best possible image quality. The Hamamatsu cameras are certainly very nice quality assemblies.
I have considered playing with CR plates but the laser readers are large and expensive, even on the secondary market.
The MX-20 will likely serve my purposes for most scenarios. I have considered whether I could use the Gendex USB digital sensor array with my Gendex 65kVp dental head for more challenging material densities. I will have to get the sensor working first though
. I might also be able to use it in my security X-Ray scanner as that produces 85kVp.
So many projects and no time at the moment.
I would love to hear of any experiments that you carry out with your X-Ray equipment. If I can ever be of assistance, please do not hesitate to ask.
Fraser
