I'm trying to build the smallest possible circuit to light a neon bulb. Ideally, I could fabricate some round PCBs about 6mm (or less) in diameter, and incorporate them into a bulb holder or bezel of some sort. The end goal is to be able to use neon NE-2 bulbs in a circuit the same way as you would use a LED, for a retro aesthetic. The main difficulty is that I want to light them with AC so that both electrodes glow; which eliminates a DCDC boost circuit. Power Efficiency isn't a primary concern, but I'd like it to keep the input current requirement to about 20mA or so. The NE-2 needs about 100V to strike, and maybe 1/2mA at 80V continuous. Right now, I'm working with the circuit attached below.
I have two questions:
1. What are my options for a transformer that's both tiny and has a high ratio of turns? Right now I've hand wound on an EE5 core which really sucks as it needs a LOT of windings, and it isn't as small as I'd like.
2. Are there any circuit improvements you can think of or alternate circuits to consider?
