Author Topic: transistor help  (Read 1020 times)
Offline rayzcam1Topic starter
transistor help
« on: June 23, 2026, 11:36:59 am »
Need help to identify this transistor 176 051  TO-92 body  It's a npn
Offline Ugur
  • Country: tr
Re: transistor help
« Reply #1 on: June 23, 2026, 12:00:47 pm »
Can you share a picture of this transistor?
Re: transistor help
« Reply #2 on: June 23, 2026, 02:15:38 pm »
yes
Offline Ugur
  • Country: tr
Re: transistor help
« Reply #3 on: June 23, 2026, 02:38:19 pm »
What device is this part used in? Are you sure it's an NPN transistor? My first thought is that it might be a J176 JFET.
Online Emo
Re: transistor help
« Reply #4 on: June 23, 2026, 03:02:09 pm »
there does exist a 2sc176, a NPN Ge transistor with max 15V and Ft 10 Mhz.
Measuring the diode voltage over the B-E junction will show if it is indeed Ge(0,3V versus 0,6V Si)
Offline Grandchuck
Re: transistor help
« Reply #5 on: June 23, 2026, 05:37:18 pm »
TO-92 germanium transistors are rare.
Re: transistor help
« Reply #6 on: June 23, 2026, 05:46:51 pm »
It's in a BK 1640 power supply
Offline PGPG
Re: transistor help
« Reply #7 on: June 23, 2026, 06:04:37 pm »
You have schematic without part list?
Having schematic you should be able to select transistor to be used there.
Offline mikerj
Re: transistor help
« Reply #8 on: June 23, 2026, 08:15:10 pm »
This part drives the base of the main pass transistor which is a 2N6383 NPN darlington.  I have no idea what that exact part is, but there are numerous jellybean parts that would work fine in this position, e.g. 2N3904.
Re: transistor help
« Reply #9 on: June 23, 2026, 08:42:33 pm »
Thank you!
Offline mikerj
Re: transistor help
« Reply #10 on: June 23, 2026, 09:29:41 pm »
Check pin outs carefully, they may not match the original so you may need to bend the pins and/or rotate the new device to shift the pins into the correct places.
