EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
transistor help
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: transistor help (Read 1047 times)
rayzcam1
Newbie
Country:
transistor help
on:
June 23, 2026, 11:36:59 am »
Need help to identify this transistor 176 051 TO-92 body It's a npn
Logged
Ugur
Regular Contributor
Country:
Re: transistor help
Reply #1 on:
June 23, 2026, 12:00:47 pm »
Can you share a picture of this transistor?
Logged
rayzcam1
Newbie
Country:
Re: transistor help
Reply #2 on:
June 23, 2026, 02:15:38 pm »
yes
Logged
Ugur
Regular Contributor
Country:
Re: transistor help
Reply #3 on:
June 23, 2026, 02:38:19 pm »
What device is this part used in? Are you sure it's an NPN transistor? My first thought is that it might be a J176 JFET.
Logged
Emo
Regular Contributor
Country:
Re: transistor help
Reply #4 on:
June 23, 2026, 03:02:09 pm »
there does exist a 2sc176, a NPN Ge transistor with max 15V and Ft 10 Mhz.
Measuring the diode voltage over the B-E junction will show if it is indeed Ge(0,3V versus 0,6V Si)
Logged
Grandchuck
Super Contributor
Country:
Re: transistor help
Reply #5 on:
June 23, 2026, 05:37:18 pm »
TO-92 germanium transistors are rare.
Logged
rayzcam1
Newbie
Country:
Re: transistor help
Reply #6 on:
June 23, 2026, 05:46:51 pm »
It's in a BK 1640 power supply
Logged
PGPG
Super Contributor
Country:
Re: transistor help
Reply #7 on:
June 23, 2026, 06:04:37 pm »
You have schematic without part list?
Having schematic you should be able to select transistor to be used there.
Logged
mikerj
Super Contributor
Country:
Re: transistor help
Reply #8 on:
June 23, 2026, 08:15:10 pm »
This part drives the base of the main pass transistor which is a 2N6383 NPN darlington. I have no idea what that exact part is, but there are numerous jellybean parts that would work fine in this position, e.g. 2N3904.
Logged
rayzcam1
Newbie
Country:
Re: transistor help
Reply #9 on:
June 23, 2026, 08:42:33 pm »
Thank you!
Logged
mikerj
Super Contributor
Country:
Re: transistor help
Reply #10 on:
June 23, 2026, 09:29:41 pm »
Check pin outs carefully, they may not match the original so you may need to bend the pins and/or rotate the new device to shift the pins into the correct places.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
transistor help
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
