Thanks. I couldnt find the spec download link when I looked earlier.
Thats because you havent paid them $10,000 yet.
Given the linear arrangement of the pins, and the fact that its a high speed serial signal, I'd suspect the one with the + and - signals next to each other and shields in between pairs would be correct. The other way would be hell for impedance and cross talk.
The +, g, - arrangement makes sense on the larger HDMI cables as the pinout staggers as it runs down the connector so you have a differential pair next to a ground, and with a ground across from it, and the next differential pair is staggered diagonally from it.
http://en.wikipedia.org/wiki/HDMII found some HDMI test fixtures looking for details on where the differential traces come from, but none of them showed a type C on a bare PCB.
