Author Topic: uLow power accelerometers with kB sized buffers  (Read 1152 times)
Offline itsfreerealestateTopic starter
« on: December 01, 2018, 05:13:54 pm »
I spotted that Bosch is releasing / has released a 3-axis ultra low power (single microamps in low power, ~14uA in full run) accelerometer. What seems unique about is it also includes a kB sized buffer which is something I've only really seen on IMUs. Was wondering if anyone had seen any similar accelerometers; the FIFO's on accelerometers tend to be a lot smaller.
https://www.mouser.com/pdfdocs/Bosch-BMA400-flyer.pdf
Cheers!
« Last Edit: December 01, 2018, 05:16:01 pm by johnuk »
Offline SiliconWizard
Re: uLow power accelerometers with kB sized buffers
« Reply #1 on: December 02, 2018, 02:35:58 am »
Yes, you can take a look at AD accelerometers for instance.
The ADXL372 is in the same ballpark (~22 µA, FIFO of 512 samples, higher max ODR).
The following users thanked this post: itsfreerealestate
