Hi guys,
I'm having some weird issues in my lab. I do a lot of ATX power supply testing, and part of this testing involves measuring output ripple and noise. The problem is, I'm getting anomalously high readings, typically 30-50mV higher than comparable labs on the exact same power supplies. The actual ripple waveform is the same magnitude, +/-5mV, when measured with V-bars, but I'm getting large spikes which throw the automated reading off, and using the V-bars is too time-consuming when I have to make 30-40 measurements.
Here is the test setup:
Tektronix TDS3014C DPO
Fluke 87V DMM
BK Precision 8512 1200W load
2x BK Precision 8540 150W loads
Extech 380820 Power Analyzer
Custom test fixture
I thought the issue was the test fixture, where the power supply cables, DC loads, and scope probes attach to the PCB. I replaced the SMA connectors for the probes, I replaced the 0.1uF ceramic caps and 10uF electrolytic caps demanded by Intel testing procedures (and upgraded from Taicon caps to equivalent NCCs), and cleaned all connectors with isopropyl. No significant change, for quite a bit of effort.
Using different probes or scope channels makes no difference. I'm considering if I might be picking up switching noise from the DC loads, or possibly conductive EMI from the mains. But I'm not sure how I could test for that. I'm kind of at a loss here.
