Author Topic: Upgrading switchboards  (Read 644 times)
Offline calzapTopic starter
« on: January 31, 2026, 07:35:24 pm »
This isn’t sophisticated but an example of simplifying and modularizing.  The switches control valves in an irrigation system.  The first picture shows the original switchboard on the right.  A replacement is on the left.  Second picture shows the innards of the red switch case.  It was a nightmare to service when something went wrong.  Taking it to the shop would have been worse than servicing it in the pump house.  But to service it there, the hinged red case had to be propped up then you had to sit on the floor and try to diagnose and fix it.  The enable switches in the bottom row were never used. The valves use 24 VAC; the LEDs used 9 VDC which is why the switches were double pole.  The availability of ready-to-use 24 VAC LEDs and no need for enable switches made replacement simple.  All that was needed was a SPST switch, LED and diode for each valve circuit box (last pic).  The diodes are used to power a shared flashing LED on the outside of the pump house.  Having a separate module on DIN rail for each valve makes service easy.  Disconnect the box, remove from rail and install a spare.   Mike
Offline coppercone2
  • √Y√... 📎
Re: Upgrading switchboards
« Reply #1 on: January 31, 2026, 07:59:21 pm »
I think the only thing you missed is the switch in picture 3, it might have a anti-rotation feature that is just pressed into the chassis and tilting... looks like the switch is not parallel to the wall its mounted on.   (might be easy to solve with a small ball burr to make a indent on the chassis), and a cable gland might help depending on how its oriented (if things can drip into the chassis),
I just got myself a roll of fiberglass ptfe lacing tape, so I can tie down things like diodes to a little 'stand off', but that is probobly going too far for something like your project. A few times I have used a zip-tie holder to anchor a through hole fuse or diode, and I think it would be nice if I could get something more temperature resistant then a zip tie holder and a zip tie (though zip ties can be impressive if you get the blue high temp ones). A small PTFE thing (or fiberglass rod) with a hole and a saddle to tie down parts into is my goal (that has a screw on the other end), then it should be OK even if there is some gross overheating... still working on figuring out what might be a good solution
For anything complicated, I just got those old point to point strips that can have components soldered to them, to get rid of floating parts when they appear in large numbers. I got a life time amount of those lol, but I think it would be nice to have a solution when there is like a single part in a pretty tight space.
this is what I am working on
I renemebr a while back I got annoyed to hell by a neon bulb holder in some HP equipment for the indicator light. Little plastic clip piece of shit, I wonder if my idea would work for that too.
« Last Edit: January 31, 2026, 08:29:35 pm by coppercone2 »
The following users thanked this post: calzap
« Reply #2 on: February 01, 2026, 01:55:58 am »
Thanks for the tips.  I think in the case of the switch not being flush with the inside of the box that the nut on the switch had not been fully tightened when the photo was taken.  In use, the switches have been physically solid.          Mike
Offline coppercone2
  • √Y√... 📎
« Reply #3 on: February 01, 2026, 01:57:10 am »
I noticed some switches have a little cylinder, and most have a special washer that that is designed to go into a hole, particularly useful for plastic enclosures
Actually a good features, because its some what possible for a switch to rotate, if you use a cylinder hole (not keyed)... if the wire is long enough it could get 180 degrees rotated
« Last Edit: February 01, 2026, 01:58:49 am by coppercone2 »
