I think the only thing you missed is the switch in picture 3, it might have a anti-rotation feature that is just pressed into the chassis and tilting... looks like the switch is not parallel to the wall its mounted on. (might be easy to solve with a small ball burr to make a indent on the chassis), and a cable gland might help depending on how its oriented (if things can drip into the chassis),
I just got myself a roll of fiberglass ptfe lacing tape, so I can tie down things like diodes to a little 'stand off', but that is probobly going too far for something like your project. A few times I have used a zip-tie holder to anchor a through hole fuse or diode, and I think it would be nice if I could get something more temperature resistant then a zip tie holder and a zip tie (though zip ties can be impressive if you get the blue high temp ones). A small PTFE thing (or fiberglass rod) with a hole and a saddle to tie down parts into is my goal (that has a screw on the other end), then it should be OK even if there is some gross overheating... still working on figuring out what might be a good solution
For anything complicated, I just got those old point to point strips that can have components soldered to them, to get rid of floating parts when they appear in large numbers. I got a life time amount of those lol, but I think it would be nice to have a solution when there is like a single part in a pretty tight space.
this is what I am working on
I renemebr a while back I got annoyed to hell by a neon bulb holder in some HP equipment for the indicator light. Little plastic clip piece of shit, I wonder if my idea would work for that too.
