Author Topic: overcomplicated wiring for guitar!  (Read 2295 times)
Offline Deactivated-1Topic starter
« on: October 10, 2019, 03:06:16 pm »
I am trying to make a circuit for a guitar that would be able to get every possible sound out of 3 "humbucker" pickups. it uses 3 4 pole 6-way rotary switches 3 volume controls that and tone control that is meant to be switchable from high pass to low pass. the tone control really seems that it would be a problem and hard to make it work and also would mixing a p90 pickup whit a humbucker work?
here is the public schematic for it: https://easyeda.com/evalc2636/all-config-pickups
« Last Edit: October 15, 2019, 03:04:17 pm by ELS122 »
Offline 001
  • Country: aq
Re: will this work?
« Reply #1 on: October 10, 2019, 03:57:15 pm »
Oh boy
All guitar guys I hear for last 40yrs were equipped with stock or duncan humbuckers since all additional wirings kills  sound ( signal/hum ratio is bad).
Offline Benta
Re: will this work?
« Reply #2 on: October 10, 2019, 04:47:27 pm »
With all those switches, you won't have time to play the guitar.   :-DD
Personally, I found the Stratocaster switch brilliant (in both senses).
Offline SiliconWizard
Re: will this work?
« Reply #3 on: October 10, 2019, 07:04:32 pm »
Why not, Brian May had guitars with many switches, so you're not first. ;D (He even has a shop now, so you can take a look: https://shop.brianmayguitars.co.uk/ )
The following users thanked this post: Bud, Gyro
Re: overcomplicated wiring for guitar!
« Reply #4 on: October 15, 2019, 03:11:29 pm »
Use stacked pots.
Offline Bassman59
  • Yes, I do this for a living
« Reply #5 on: October 15, 2019, 05:25:35 pm »
ok so I found some stacked push-pull type pots on amazon so I'll probably be okay whit that!
Stewart-MacDonald has a selection of push-pull (and other) pots.
Probably pricier than Amazon but they offer excellent customer service.
Offline Bassman59
« Reply #6 on: October 16, 2019, 05:02:42 pm »
So would this tone circuit work for what I'm building?
What are you trying to achieve, exactly? I find I just leave my tone controls wide open (no roll-off) and I switch to the neck pickup for a darker sound.
