Voltage does not mean much for alkaline batteries. When it's above 1V5 it's full, and when below 0V9 it's empty but in between a lot of things happen, especially with old or long unused batteries.
It's fairly common for old batteries to have a high voltage (1V3), but then the voltage sags quickly when you attempt to use them. A much better indication is when the batteries stop to be able to deliver current (power) to your appliance. Measuring alkaline cells by shorting them with an 1Ohm resistor is good. Current will never be more then 1A5, and when you do this for a handful of seconds, you also get an idea of how quickly the current sags under a load. Note that an AA cell has about 2Ah capacity, so a 10 seconds test @1A is 0.1% loss of energy. Also note that during a high current test, the voltage will always sag because of the internal resistance of the battery. As long as it's still capable to deliver >100mA there is some life left in it. Maybe its not good enough for your fancy electronic gadget, but it may still work appropriately in a flashlight. Especially single cell flashlights have an SMPS that can squeeze the last drop of energy out of a battery. But I do prefer flashlights that slowly decrease their light output when the battery depletes, as this is a built in double function as a battery tester.
