So this is my first time designing a high power transformer, last time it was like 10 W and i was like way off in terms of inductance ( math was off ).
So i am posting here since this time this is way more dangerous and it is in a larger design so i am sort of want to have something at least functional this time, first try maybe not full power maybe not full voltage range but at leat to work at nominal at lets say 50% . Last time i had like 1/2- 1/3 the inductance i needed and tons of leakage inductance and it ended in a mess.
So here is the design details:
topology Full bridge 500 kHz switching ( so fets work at like 250kHz) transformer is planar design
Vin 300V+ mostly 380-410vDc 390Vdc nominal ( 300vdc since it will start with that and then powers the APFC stage that gives 390v nominal, the APFC stage works and it was tested a bit already in another design)
Vout 48V nominal maybe 55-60V to compensate cables @ 5A ( i would be happy with 1A min first try)
On the secondary i will have a centre taped winding and there is a bias winding that feeds the APFC with about 12 V ( it accepts max 22v but i sort of need 10.5-11.5 min to be same so maybe 12 is a bit to close )
So according to my math at nominal i would need 6: 1 :0.25 transformer or rather 24 pri / 4 sec / 1-2 aux
According to TI datasheet i would need about 2.5 mH. So i want to did the math for a ton of cores that fit my size restrains and are available online.
Here is what i ended up with : EI Core: ELP 22/6/16 Material: N95
https://www.tdk-electronics.tdk.com/inf/80/db/fer/elp_22_6_16.pdf https://www.tdk-electronics.tdk.com/inf/80/db/fer/elp_22_6_16.pdf why N95 , because the winding number looked great on paper : 20.2 → 20 3.4 → 3
BUT if i round up i get 22 / 4 ( 5.5 / 1 ratio ) and that looks way better since it can be made symmetrical and have 2 winding per layer.
IF i redo all the math in reverse i get 2.95 mH primary inductance with
Bpeak=Np⋅AeV⋅ton
Bpeak=400⋅1×10−622⋅78.5×10−6=4001.727≈0.232 T
Bpeak=22⋅78.5×10−6400⋅1×10−6=1.727400≈0.232 T
So i dont think it will saturate
BUT now my ratio is 5.5/1 i am not sure if this is ok on one hand yea i can compensate a bit more in terms of loses but then again will i even have loses that big?
So here is the alternative: 24 / 4 here i keep the ratio and increase the primary winding number.
So here is what i get ( with the same core and material) :
Lp=Np2⋅AL=242⋅6100=576⋅6100=3,513,600 nH=3.51 mH
Bpeak=Np⋅AeV⋅ton=24⋅78.5×10−6400⋅1×10−6=1.884400≈0.212 T
More inductance on the primary should be a good things since it will theoretically enable me to lower my switching frequency or deliver more power. but for now ill be very happy to just get part of what i design for.
So here is my dilemmas:
A) Should i use 22 or 24 wingdings on the primary? I sort of excluded 23 since i cant get that with a symmetrical transformer design . Or maybe have 23 and also have the bias winding on that layer instead of an additional primary winding?
B) Regarding the aux i am again not sure if i should use 1 or 2 winding, 1 m,ay be to little to power my APFC but 2 is a bit to much tho i can use a resistor and zener to clamp it to 20 V ish but i am afraid not to make a heating element . Here i am sort of leaning heavily on 2 windings but i am still sceptic since it is low power i have a bit more options.
C) What PCB trace width should i use for the transformer ? Should i go with 1mm/ 1 Arms?
D) Am i even close to reality? Last time i was way of in winding number ( tho then i had air gap and that might have also been part of my problems since i might have also added extra air gap with glue.
NOTE: Transformer is planar since i have 10 mm height for the entire design due to mechanical constraints ( and it also helps with electrical safety since it is easier to check since stuff is not touching randomly).
I find it easier to design and it sort of makes me feel safer, since hand winding something like that makes me super nervous and 400 Vdc is SUPER DANGEROUS.
With that core i have 3.2 mm so basically 2 PCBs will have all the windings, based on width i think i can get away with 6-8 layers per PCB .
Sorry of my tone sounded sad or to pessimistic, i am just coming from a few failed designs and i sort of lost my confidence + this time the voltages are also dangerous so there is even less margin for error.
THX in advance for your help.
