Author Topic: Component identification  (Read 1193 times)
Offline eduaqaTopic starter
« on: June 05, 2022, 11:36:47 pm »
I have a FAN controller (home decorators) which control a 3 phase variable speed motor and the dim light
But the important is:
There is a sto23-5 that supposed provide power for the MCU and remote control receiver portion, but on the 5v point test i only have  5v peek on 60hz but just 10 percent duty, so the MCU don’t have power to run
This sto23-5 receive 170vdc (rectified from 120vac), it has a few capacitor, resistor e diode around
On the bottom it has C278 noted and on the top it has IAFAK noted
Any idea what is that?
Offline fzabkar
Re: Component identification
« Reply #1 on: June 06, 2022, 02:04:56 am »
MP156GJ, Monolithic Power, Small, Energy-Efficient, Off-line Regulator, 30mW No-Load Power Consumption, marking AFA, TSOT23-5:
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MP156/
The "I" is actually a vertical line which is a characteristic of most Monolithic Power ICs.
« Last Edit: June 06, 2022, 02:10:34 am by fzabkar »
« Reply #2 on: September 05, 2022, 06:27:05 pm »
Thanks fazbkar, you are right. Now next question would be, any idea where I can buy it? I checked digikey and mouser but the restock will be in 1 year. Any idea where to buy? Or if there are a replacement? I just need 1 (or couple for spare) to fix my fan that use DC Motor.
Offline fzabkar
« Reply #3 on: September 05, 2022, 06:46:43 pm »
I tried Farnell and RS-Online, but no luck. :-(
