Author Topic: Cursed CPU  (Read 5263 times)
Offline james_s
Re: Cursed CPU
« Reply #25 on: July 02, 2018, 09:48:53 pm »
Unlikely yes, but I find the idea of a motherboard or CPU killing power supplies to be at least equally unlikely. I too am curious to know what the root cause turns out to be.
Offline rdaggerTopic starter
    • Rototron
Re: Cursed CPU
« Reply #26 on: July 02, 2018, 10:40:04 pm »
Despite the blown cap shown in my first post, the power supply tester shows that the PS is OK (for what it's worth).  During testing, I hooked the PS up to a 1 amp server fan.  The tester does not put a load on the PS.  Unfortunately I stripped the CPU cooler mount when I removed the PS so I'll have to wait until I can tap a new mount.
btw:  The blown cap is under the bundle of wires at the bottom right of the photo.
Offline shakalnokturn
Re: Cursed CPU
« Reply #27 on: July 02, 2018, 10:55:15 pm »
What more does a PSU tester do than the voltage monitor in the BIOS?
    • Rototron
Re: Cursed CPU
« Reply #28 on: July 02, 2018, 11:12:41 pm »
Nothing, but the computer won't boot to BIOS.  It definitely won't tell definitively if the PS is good.
I'm leaning toward a bad motherboard.  I'm going to put the PS back together and throw it in another computer.  I think it might work despite the bad cap.
    • Rototron
Re: Cursed CPU
« Reply #29 on: July 02, 2018, 11:47:27 pm »
Am I wrong about the failed cap?  Is it a Chemi-con aluminum polymer 470uF 16V cap?  Could the brown discharge on the side be something else?
Offline james_s
Re: Cursed CPU
« Reply #30 on: July 03, 2018, 12:46:08 am »
I suppose it could be some kind of glue, I can't tell from the picture where it came from since it's on multiple parts.
Offline andy2000
Re: Cursed CPU
« Reply #31 on: July 03, 2018, 01:28:27 am »
It looks like glue to me, but clean it off and see what's underneath to be sure.  One thing is certain, no overload could cause a cap to blow its top.
    • Rototron
Re: Cursed CPU
« Reply #32 on: July 03, 2018, 02:34:54 am »
I think you're right. I misdiagnosed the bad cap (rookie mistake).  It looks like yellow glue that turned brown from heat.  There's probably nothing wrong with the PS.  I guess it's the MB.
Offline bob225
Re: Cursed CPU
« Reply #33 on: July 03, 2018, 10:25:41 am »
pull the board out of the case and bench test it, reset the bios and use the onboard graphics
