Author Topic: CyberHome CH-DVD 300 DVD player no power repair  (Read 2573 times)
Offline poot36Topic starter
« on: December 04, 2021, 10:20:25 pm »
Lets take a look at why it will not power on.
Outside pictures attached.
Re: CyberHome CH-DVD 300 DVD player no power repair
« Reply #1 on: December 04, 2021, 10:22:04 pm »
Inside pictures, can you spot the issue yet?
« Reply #2 on: December 04, 2021, 10:22:50 pm »
Power supply board.
« Reply #3 on: December 04, 2021, 10:24:52 pm »
Lets replace that bad cap, and the tester says... bad.
Replacement cap in second picture.
« Reply #4 on: December 04, 2021, 10:25:38 pm »
All working now.  Green power light it a bit hard to see.  The bad cap was on the 5V rail that was also part of the feedback section of the power supply so no wonder it would not power up.  This unit takes a 12V and 5V rail to operate.
« Last Edit: December 04, 2021, 10:27:21 pm by poot36 »
Offline CaptDon
  • Country: is
« Reply #5 on: December 05, 2021, 04:26:52 am »
That sure was a shit load of pictures and posts just to see a bulging bad capacitor? I own two of these both with the same identical problem. It is a pain in the ass to get them to open the tray if they sit a few days!! I found that leaving a worthless CDR in the tray when not using the unit seems to help. They are VERY unique because there is a super simple button press hack that makes them 'region free'!!! That is why I own two!!
« Reply #6 on: December 06, 2021, 12:25:02 am »
It also has a serial port but I am not sure what it does as this was a friends unit and I was only asked to fix it not turning on.
