Just to help (hopefully) help you know what is important:
1) "normal" Network cable (CAT5 or later) is all somewhere around 24AWG. Although you can find networking patch cables which are smaller, standard cable usable with standard ends will all be about that size.
2) Matching CAT rating and stranded/solid and shielded/unshielded are all important when selecting ends for a cable. Using stranded cable with crimp-on-ends that are only for solid doesn't work. Trying to use CAT6 in a CAT5 end often doesn't work due to the wire dimensions/sizes being different. And so on.
3) The ethernet standard assume you have stranded patch cables at both ends and solid in the middle. Although that's the standard, it's perfectly acceptable to just crimp an end on Solid cable. But it needs to be a connector designed for that. Not having the stranded patches at each end aren't going to affect performance - using stranded for a long run including the middle might.
4) It is critical that you put each pair of wires in the right spot on the cable. I'm not talking "same spot" at both ends, but that you have a pair on 1,2. And another pair on 7,8, and another pair on 4,5 and finally a pair on 3,6 (note these aren't next to each other). If you instead put a pair on 1,2, another on 3,4, another on 5,6 and the last on 7,8, the cable won't work correctly. There are standards for which colors of wires go on each pin, follow them and this will work out correctly.
5) a properly terminated cable is pretty much impervious to any external interference you're likely to encounter in a house - power strip, extension cords, wifi router, etc.
6) Having crimped (or troubleshot someone else's crimping) way too many times in my life - the crimper and ends being of decent quality and compatible with each other (and the wire) is important. Buying expensive tools and ends don't guarantee this. I.E. there is very little correlation between acceptablity of a tool and it's price.
7) I don't know about your budget here - or what you have, or if this is available in your country, but I will make a recommendation of a specific example of a tool kit I like. Klein makes a VDV226-107 crimper which works really well with klein branded passthrough ends. In addition, there's a klein VDV526-200 tester which will check for all of the common miswires. You can often find a kit with the tester, crimper, and ends for around $100 total. This should be a "lifetime" purchase unless you're using this professionally.
8 ) Don't feel obligated to buy the specific kit in #7. It's just one I've finally found that is a good combination of "cheap enough to be affordable" and "expensive enough to work". It's more an example than a "you must buy this crimper".
9) The passthrough ends in #7 can be controversial as some people have had bad luck with them, but I find that I fight them a lot less than I do a standard end. With these, when making up the cable you push each wire all the way through the connector and then can tug on them, make sure they're in the right spot, and everything before you crimp it. The crimp cuts the ends off as part of the procedure.
10) If I was to guess what is wrong in your setup: Either you have the wrong cable, or wrong ends for that cable - with a small chance that you have a split pair (meaning pairs aren't in the right spot even though you have end-to-end connectivity). The reason I say there's a small chance for the split pair is that at the lengths you're working, the pairing being acceptable is less important. On the other hand, you saying that that the position of the cable matters is a good argument for the split pair issue.
