Author Topic: Lecroy DDA-5005 - Firmware / HDD Image  (Read 2708 times)
Offline sixtimessevenTopic starter
    • Flickr
« on: November 20, 2019, 10:57:49 pm »
Hi
I have a Lecroy DDA-5005 with a faulty hard drive. Unfortunatly I did not find a image of the drive so far. Since the device is obsolete I doubt that Lecroy will hand over the image, but maybe someone has cloned one?
Thank you very much!
« Last Edit: November 21, 2019, 08:58:03 am by sixtimesseven »
Online DaJMasta
    • medpants.com
Re: Lecroy DDA-5005
« Reply #1 on: November 21, 2019, 03:14:20 am »
You shouldn't really need it.  Get a new drive, install windows and take it from there.  Just recovered a WP7300 in that manner, and it's documented somewhat in the thread in the test equipment section.  Through the service menu it's possible to recal as well, though you want a separate partition for it (I think the defaults are FIRMWARE on C and USERDATA on D).
Basically it's:
Install XP
Install chipset drivers
Install XStream
Install XStream drivers
Install touch screen drivers
The following users thanked this post: sixtimesseven
    • Flickr
Re: Lecroy DDA-5005
« Reply #2 on: November 26, 2019, 02:46:24 pm »
Basically it's:
Install XP
Install XStream
Well I had a look in the thread but I cannot seem to find where to actually get the x-stream firmware and drivers?
I haven't found anything on the Lecroy website as well. Do I have to ask them directly and hope they hand it out or is there a mirror somewhere?
Offline LateLesley
  • Country: scotland
Re: Lecroy DDA-5005 - Firmware / HDD Image
« Reply #3 on: November 27, 2019, 10:10:09 pm »
Could you get the software from here??
https://teledynelecroy.com/support/softwaredownload/documents.aspx?sc=17
(choose Disk Drive Analyzers (DDA 3xxx, 5xxx) )
The following users thanked this post: sixtimesseven, TysonZ
    • Flickr
« Reply #4 on: November 28, 2019, 09:41:22 am »
Ah... thank you. I seem to have overlooked that part  |O
Offline spilihps
« Reply #5 on: November 28, 2019, 07:03:58 pm »
Is that also a XP Embedded install?
I was trying to get hold of all the software components to make a "rescue"disk for my LeCroy 454 incase of harddrive failure. I have everything but the xp embedded media.
LeCroy wont send that.
    • Flickr
« Reply #6 on: November 28, 2019, 07:08:58 pm »
I don't know about the 454 but the 7000 and 8000 series use the normal desktop win2000 or winXP afaik(?)
Offline spilihps
« Reply #7 on: November 28, 2019, 07:24:26 pm »
Ah i see! Does it have the key-sticker in it and all then? Then you are in luck! :)
    • Flickr
« Reply #8 on: November 28, 2019, 07:46:18 pm »
Even if you have no key sticker - win2k and xp and win7 keys are floating around in the www pretty freely these days. The good old days before online key validation :-DD
Offline coromonadalix
« Reply #9 on: November 29, 2019, 02:11:36 am »
Yep  tons of keys are available  :)
Hacked  cough cough  an Xp installation recently  with an dll injection ...  wga removal   cough cough  loll
« Last Edit: November 29, 2019, 02:13:16 am by coromonadalix »
    • Flickr
« Reply #10 on: December 07, 2019, 01:38:55 am »
I'm trying to get the dam thing to work but the best I got so far is a kind of demo mode  :palm:
https://www.eevblog.com/forum/testgear/upgrading-mainboard-in-lecroy-dda-3000-(aka-wavepro-7300a)/msg2818252/#msg2818252
Maybe someone from this thread has a idea?
