Author Topic: Looking for help to identify component  (Read 1891 times)
Offline narbuzovTopic starter
« on: May 24, 2019, 06:30:14 am »
Hello,
I got an old IBM laptop  from ebay and it worked for 5 minutes and died. Once opened I discovered some signs of leakage around component
that I am not sure about. I've seen capacitors leaking, but this looks like some kind voltage regulator.
On the picture attached I am pointing to the substance around that area. Most of it was around MAX637 (switching regulator)  and SMD10 . Capacitors near was clean and looked good.
Anyone can help me to identify that SMD10 component ? Could it leak ?
Thank you!
« Last Edit: May 24, 2019, 06:33:41 am by narbuzov »
Online ataradov
    • Personal site
Re: Looking for help to identify component
« Reply #1 on: May 24, 2019, 07:01:09 am »
They are transistors and they can't leak.
The leakage is likely from the two electrolytic capacitors, which leads don't look so fresh. Or something else entirely.
Alex
« Reply #2 on: May 24, 2019, 07:04:13 am »
This is what I though. Will try swapping capacitors.
Offline amyk
« Reply #3 on: May 24, 2019, 11:53:23 am »
SMD10P p-channel MOSFETs.
Offline eevcandies
« Reply #4 on: May 24, 2019, 09:49:55 pm »
That could be a spill/accident.  What do you meant it no longer works?
try cleaning with denature (rubbing alcohol)
« Last Edit: May 24, 2019, 09:51:34 pm by eevcandies »
Offline DaJMasta
    • medpants.com
« Reply #5 on: May 24, 2019, 09:58:36 pm »
Especially if it's under a vent or something, I'd suspect a spill or something else as well.  Could be the caps, but you'd think there would be a little pooling under them, unless the unit was oriented that the transistors were downward from the caps when the leak happened.
« Reply #6 on: May 25, 2019, 01:00:41 am »
Once received I plugged it in and it turned on normally. Everything was good for about 2-3 minutes.
Later screen went black. but indicator panel  is partially functional (e-g battery charging showing something, caps-lock, num-lock showing something ).
 At that point i took it apart and discovered that substance and it was kinda bubbling around these elements. I cleaned up the area and after power is on I don't see more of the substance coming out from any elements.
Other thing I noticed that heatsink on the back of the laptop where power plugs-in is getting very hot.
So at this point I ordered capacitors as a first step in attempt to repair it.
Thanks.
« Reply #7 on: May 25, 2019, 01:03:06 am »
There was no indication of liquid spell. FDD disk was above that area and it look very clean. I took keyboard apart and did not see any signs of liquid some dust - yes but no leaks.
Thanks.
