Author Topic: Need Calibration Error Code List Fluke PM3380A Please.  (Read 6535 times)
Offline Jesus Benitez LuenzaTopic starter
« on: February 28, 2016, 09:36:55 am »
Hello, I am repairing an oscilloscope fluke PM3380A. On having autocalibrated the mistake appears 111. Error Nº 111 Repeat calibration.
Can someone help me with the list of mistakes or if I repair this breakdown?.
The equipment was presenting tracks cut by dampness.
The observed failure is: The outline N º 2 this one very much down below that the brand of zero.With POS X I can raise it up to centring it but the brand rises. And the applied sign is deformed as the outline is raised on screen.The alone failure happens in digital way, in analogical it goes perfectly and in the digital channel N º 1  also it works well.
I am grateful for any help. Thank you very much for anticipated.
Necesitaria la definicion de codigos de error en calibracion para este osciloscopio, o para el error 111. Los fallos que presenta son no pasar el autocalibrado y solo el trazo 2 en digital aparece por debajo de la marca de cero y no hay forma coincidan. Si se sube a mano no llega a salir por arriba de la pantalla, y la marca sube con él. Aparte la señal aplicada se deforma segun subimos el trazo.
Muchas gracias por todo.
Re: Need Calibration Error Code List Fluke PM3380A Please.
« Reply #1 on: February 28, 2016, 09:42:51 am »
It wanted to add that I have the technical generic manual for the series PM3370A, 90A, 82A, 84A, 92A, 94A but they do not come. I have that of the PM3370A and they come but this model is not digital and there appears the number for that I look.
Tengo el manual tecnico pero no aparece la lista de errores, en otro del modelo PM3370A si aparecen pero al no ser digital, no aparece el error que busco.
Gracias.
« Reply #2 on: February 28, 2016, 03:42:13 pm »
Channel 4 ( trigger ) affected like 2.
Canal 4 o trigger, si se visualiza aparece la linea baja como el canal 2.
Offline Carrington
« Reply #3 on: February 28, 2016, 05:45:10 pm »
Hola Jesús.
He estado buscando durante un rato y esto es todo lo que he podido encontrar (mira abajo), lo siento no encontré la respuesta.
Desafortunadamente, yo no sé nada acerca de este osciloscopio, espero que alguien pueda ayudarte.
Creo que ya tienes el manual de servicio.  ¿Verdad?
Saludos.
Hi Jesus.
I've been searching for a while and this is all that I could find (see below), but sorry I didn't find an answer/solution.
Unfortunately, I know nothing about this oscilloscope, I hope that someone can help you.
I think you already have the service manual, rigth?
Best regards.
Manuals:
http://forum.allaboutcircuits.com/threads/oscilloscope-calibration-error.50810/
http://www.edaboard.com/thread199087.html
http://www.ko4bb.com/manuals/87.218.164.175/Philips_PM3380-Users-Manual.pdf
PCtool: http://www.qsl.net/wb6ymi/
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline HighVoltage
« Reply #4 on: February 28, 2016, 09:43:13 pm »
The error list does exist but was never publicly released
The official Philips / Fluke service centers all had this list but are very tight with it, although these scope are of some age now.
Offline Carrington
« Reply #5 on: February 29, 2016, 04:46:45 pm »
@HighVoltage:
Thank you very much for your reply.  :-+
@Jesús:
Intenta contactar con Fluke o Philips.
Then you should try your luck, contact with Fluke or Philips.
Cheers.
Space Weather.
« Reply #6 on: February 29, 2016, 05:45:24 pm »
Thank Very much for HighVoltage and Carrington.
Carrington, esos manuales los tengo, antes de preguntar a la desesperada siempre busco todo lo que puedo para molestar lo minimo posible, pero de verdad muchisimas gracias por intentar ayudarme y tu tiempo.
Aun estoy luchando con la averia, ya no me hace mucha falta el codigo pues se que es pero no que buscar. Este equipo es muy complejo de reparar, usa unos circuitos especiales y trabaja con intensidad y apenas voltajes, es dificil hasta medir con multimetros las señales.
El problema se presenta en uno de los digitalizadores, por alguna razon tiene una señal de CC erronea inexistente. Leyendo el manual vi que por debajo de 200 ns/cuadricula usa los 2 para muestrear a 200 Mhz. Hice la prueba y efectivamente falla.
Aparte de la dificultad para medir, tengo una duda, en el capitulo 5.8-2 habla de VADCA esta señal es para poner en el centro de la pantalla el trazo cuando no hay señal, pero la comparo con el otro canal y regulan igual ( mismos margenes ) aunque en pantalla no es asi, no se si tiene un offset erroneo o la señal de GND ( GND Mark ) la que marca la posicion del trazo, es la que esta mal. Me inclino por la primera, algo distorsiona el canal 2, y afecta a los 2 canales ( 2 y 4 ) porque es comun al mismo digitalizador.
Bueno voy a seguir escudriñando señal por señal a ver si doy con la averia. Muchas gracias por todo y perdon por extenderme, la desesperacion de no poder preguntar o pedir ayuda seguramente.
Offline SAUL BRITTO
  • Country: br
  • Don't Make a Mistake
« Reply #7 on: March 06, 2016, 08:16:34 pm »
Se seu osciloscópio não guarda os ajustes de calibragem está mais que explícito: O defeito é na memória! Observe se ele tem alguma bateria esgotada.
If your oscilloscope does not store the calibration settings, is more than explicit: defect in memory. Look if it has some battery exhausted. Maybe something like that NVram.
« Last Edit: March 06, 2016, 08:41:49 pm by SAUL BRITTO »
Thank You, for all earth.
Offline TAMHAN
  • Country: sk
« Reply #8 on: March 06, 2016, 10:15:37 pm »
I have to suggest someone else.
info aeht ElectronicsAndBooks.com
http://ElectronicsAndBooks.com
WEB ElectronicsAndBooks DOT com
TEL XXX
Netherlands
This Danishman has an awful lot of stuff re Phillips and sells it cheaply. Manuals also, so maybe email him.
Feel like some additional tamile wisdom? Visit my YouTube channel -> https://www.youtube.com/user/MrTamhan for 10min tid-bits!
Offline SAUL BRITTO
  • Country: br
« Last Edit: March 06, 2016, 10:45:18 pm by SAUL BRITTO »
Offline HighVoltage
« Reply #10 on: March 07, 2016, 08:06:47 am »
The Service Manual has been available for many years but unfortunately the error code list is not part of it.
Offline SAUL BRITTO
  • Country: br
« Reply #11 on: March 07, 2016, 10:54:25 am »
Look: You calibrate an oscilloscope and ends when it says: run calibration again...
This don't looks like a memory problem?
Offline HighVoltage
« Reply #12 on: March 07, 2016, 09:22:54 pm »
This probably means that one trace is not at 0 without input, right
