Yes, and your adjustment still feels wrong.
Thanks for your use of "feel" now. You are entitled to have your feelings, whatever they might be!
Just to be absolutely clear, I'm not saying 100% absolutely the formula I reached is correct. I
can be wrong!
It has been to long since doing this kind of math, ...
That's all good. Same here. Most of us are probably not mathematicians I would guess.
..., but you are using C * R1, which is not the correct base for doing the calculations.
Don't quite get this, since there is an "r" in the equation.
The numbering of your resistors is wrong for proper formulating this, but since both 10K resistors are named R1 and of the same value I'm using it in both terms.
I'm OK with that. Here R1/R2 are not meant to be numbering, but rather variables for the resistance to make it (a little bit) more generic. Since the two resistors have the same value, they are represented by R1, which is OK to me. This even does not lose the generality for the cases when the R's at the LHS and RHS of C are different.
What I have done is simply 1) a specific definition of the problem, based on reasonable simplification from the real world one, and 2) tackle that defined problem with mathematical methods and electronic rules. Simple as that. There is no intention to be perfect or cover cases beyond what has been specified.
The RC time in this case is C * ((R1 * (R1' + R2)) / (2R1 + R2))) Due to the fact that R2 is big compared to R1 the difference is not that big. Only ~120 Ohms.
The capacitor will only charge to the Thevenin equivalent voltage, which is calculated by V * ((R1' + R2) / (2R1 + R2)), which is only slightly less then V.
Don't completely get this. But I didn't say that the final Vc will be less than V,
at a greater magnitude than it should be (according to the formula and the values of the components).
These are the values to use in the calculation for determining the voltage across the capacitor over time.
Edit: to explain, the resistance to use for the RC time is also based on the Thevenin equivalent of them being in parallel, that is R1 is parallel to the series resistance of R1' and R2.
Elaboration or, even better, step-by-step derivation would be great. But, of course, no obligations!
Only one point, I get the point of resistors in parallel. But note that it's only one 'branch' of the parallel that's charging the C.
