« Reply #79 on: May 31, 2017, 08:27:59 pm »
Actually, I have just changed that C546 and R546 as they were burned and shorted.
I did not change transistors Q540,542,530 or 532.
With the diode test they checked OK.
Funny seeing that pic of yours, I thought hey that looks familiar.
I rebuilt the Current Switch CR140 etc and new transistors Q140 and Q175. There was a lot of flux in this area from the previous owner and when I touched the connection between the diodes and resistor it just fell apart.
Replaced resistor R284 which was burned and cracked.
Checking Pin 6 output on U140 and U175 varying voltage while moving the Frequency knob.
The timing capacitors check out fine.
Yet, I have never had a Frequency output waveform or an output trigger waveform.
The Trigger Output is dead.
The main output has voltage which can be varied by the amplitude switch of near 0 - 1.3 Vdc.
I am still working my way through since changing those parts.
But I imagine I have some dead transistors somewhere.
I still get no waveform at Q290.
Will have to work on this tonight.
« Last Edit: May 31, 2017, 09:12:35 pm by Johnny10 »
Logged
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
