Author Topic: Replacing board mounted USB B mini connectors with USB C  (Read 370 times)
Offline aprusekTopic starter
« on: May 13, 2024, 10:42:42 pm »
Has anyone have any luck finding pin compatible USB C connectors that can be used to replace USB B mini connectors?
Online wraper
  • Country: lv
Re: Replacing board mounted USB B mini connectors with USB C
« Reply #1 on: May 13, 2024, 10:50:30 pm »
Forget about it, there aren't and cannot possibly be.
Offline thm_w
  • Non-expert
« Reply #2 on: May 13, 2024, 11:21:46 pm »
If you have space use chassis mount instead
https://www.aliexpress.us/item/3256806789033499.html snap in
https://www.aliexpress.us/item/3256806753403420.html screw in
https://www.aliexpress.us/item/3256806084688866.html round
https://www.aliexpress.us/item/3256805945099380.html power only
Maybe could epoxy a break out module to the pcb, not a great option though.
Offline ataradov
    • Personal site
« Reply #3 on: May 14, 2024, 12:57:00 am »
It is not  even theoretically possible to make a generic replacement that needs data transfer. Assuming only one device role and no OTG support, it would be possible, but there is no chance anyone would make anything like this. Especially for this relatively rare through hole package.
And even with the linked connectors you would still need CCx resistors, which makes the whole thing messy.
Alex
Offline thm_w
  • Non-expert
« Reply #4 on: May 15, 2024, 12:10:53 am »
Some of them include CCx resistors.
Here is even one with LEDs too: https://www.aliexpress.us/item/1005006640650907.html
If its just for charging its not messy at all, very simple.
