Author Topic: Aten Slideaway KVM power supply repair  (Read 4033 times)
Offline hanakpTopic starter
  • Country: cz
« on: September 12, 2022, 03:23:12 pm »
I thought this would be another straightforward repair, but I was in for a surprise, so I'm mentioning it here.
We have several Aten Slideaway CL5808N KVMs in my workplace and one of them stopped working. Interestingly, the LCD monitor displayed a logo upon powerup, but the rest (keyboard and KVM itself) was completely dead. That happened because the LCD is powered from 12 V supply, but the rest from 5 V supply. There is only one 12 V SMPS in the unit (Mean Well RPS-60-12) and the 5 V rail is derived by a step-down converter on a small separate PCB. The converter was dead and apparently it's not available as a spare part (it has part number KL1516-AAX-32 on the underside). I feared the faulty converter may have damaged the rest of the KVM, but luckily it worked normally when I powered it from a benchtop 5 V supply.
I haven't even tried to repair the converter board, I have poor track record with such power electronics - when I replace one component, another usually fails within a few months. The question was, how to replace the board and here I run into difficulties. The KVM normally pulls about 0.7 A from the 5 V rail, so I thought 2-ampere 78xx drop-in converter Recom R-78B5.0-2.0 would be fine. Well, it wasn't, the KVM rapidly restarted itself and its beeper produced odd chirping sound. I assumed it's because the KVM has large inrush current, so I used 5-amp Bel Power SRBA-06E2ALG module next. That worked fine, but I had to insulate the entire module so it wouldn't short-circuit with KVM case or someting else. When I covered it with shrink tubing, its temperature quickly rose to 90 deg. C - it was obvious it wouldn't last very long. Finally, I tried another 78xx drop-in converter, this time 3-amp Gaptec LC78_05-3.0. With that one, the KVM finally works and the converter runs at only about 40 deg. C. The rest should be obvious from the photos, it's ugly, but works. BTW, don't get fooled by the wires, their colors don't reflect the voltages nor their polarity.
« Last Edit: September 13, 2022, 10:56:41 am by hanakp »
Offline btjtaylor
Re: Aten Slideaway KVM power supply repair
« Reply #1 on: July 03, 2024, 07:37:46 am »
Thank you very much for making this post, I have an Altusen (I believe Aten is the same company) KL9116 slide-out KVM that I use for occasional troubleshooting etc of some rack mounted servers I have at home for learning/project purposes,
I got the device for free from an old workplace years ago and recently it died in the same way as yours - the LCD powers up but the KVM itself is dead.
I briefly opened it and everything looked to be in OK condition internally (I was hoping to see something obviously burned out). On my multimeter is was finding 12v all over the boards inside so I put it to one side.  I didn't want to spend a lot of money on a replacement unit (they are surprisingly expensive second hand, normally this kind of stuff is almost worthless, and I didnt want to go for a different brand as I would've had to buy a whole new set of cables etc) so figured i'd return to it at some point.
That day came and I had another search on google today and found your post and checked and I am also not finding 5v anywhere inside so it looks to be the same problem - based on your photos I have the same board inside too - I will order the Gaptec component you mentioned and fingers crossed it will mean a successful repair,
Is your repair still working OK?
« Last Edit: July 03, 2024, 07:54:49 am by btjtaylor »
Offline btjtaylor
« Reply #2 on: July 05, 2024, 02:38:23 pm »
I had a look for the component you mentioned but I couldnt find one locally and I didn't really want to spend €12 on shipping a small component so I ordered a very cheap PCB from ebay with the closest specs I could find - "MP2307 12V to 5V 3A DC-DC Step-Down Power Converter Module/Charger" (https://www.ebay.co.uk/itm/325318890675?var=514216054465)
It arrived this morning and I quickly installed it into the device. I had to spend a bit of time missing with the pot on the board to adjust the voltage as out of the box it was reading around 9.5v, but managed to get it so it read 5.12v which is close enough. I wired it up basically as per your photos - I was able to secure it down in place of the existing board with only a single screw which is not ideal but it'll do the job
And the moment of truth.... success!
Offline chengtse
  • Country: tw
« Reply #3 on: November 26, 2025, 07:15:13 am »
The ATEN CL5816 monitor was receiving power, but the KVM switch itself was not.
After following the repair guidance referenced in the post, the unit was successfully restored.
The DC-to-DC module was repaired using the LY-KREE BXL240505 component (Input 12V/24V,Output 5V 5A), along with a soldering torch and insulating tape.
« Last Edit: November 26, 2025, 07:21:11 am by chengtse »
Offline Munteanu
  • Make the most of what you have
At work, we use a rack-mounted KVM switch, model ALTUSCN KL9116, equipped with an integrated LCD monitor. At one point, the device stopped functioning properly.
Symptoms
Upon startup:
The LCD monitor displayed the initial logo.
After a few seconds, the message “No input signal” appeared.
The system no longer allowed access to the connected servers.
This behavior indicated that the LCD panel itself was functional, but the main KVM unit was no longer generating a video signal.
Power Supply Analysis
After disassembling the unit, I identified the following power architecture:
A main 12 V power supply – model RPS-60W-12V
The LCD is powered directly by 12 V
The KVM motherboard operates at 5 V
The 5 V rail is generated by a DC-DC step-down converter mounted on a separate PCB
This explained why the LCD powered on (12 V was present), but the system did not function completely — the 5 V supply required for the digital logic was missing.
Fault Identification
The original step-down converter was model KL1516-AAX-32.
I disconnected the module and tested it separately using a laboratory power supply:
Input: stable 12 V
Output: 0 V (faulty)
The converter was no longer providing the required 5 V output to the motherboard. The fault was confirmed.
Adopted Solution
Since an identical replacement module was not immediately available, I chose to replace the converter with an adjustable XL4015 step-down module (75W / 5A).
Steps performed:
Adjusted the output voltage to 5 V using a multimeter.
Connected the input wires (12 V) and output wires (5 V) to the motherboard.
Mounted the module temporarily on a test board.
Verified voltage stability under load.
Testing and Verification
For safety, I monitored temperatures using an infrared thermometer:
RPS-60W-12V power supply: below 30°C
XL4015 converter: below 30°C
Adjacent components: normal operating temperatures
No overheating or instability was detected.
Conclusion
The failure was caused by the 5 V DC-DC converter, which stopped functioning and left the motherboard without power, while the LCD (powered by 12 V) continued to operate.
Replacing the step-down module restored the equipment to full working condition.
« Last Edit: February 27, 2026, 08:35:05 am by Munteanu »
