Author Topic: seller description: "Unit is in bad shape."  (Read 897 times)
golden_labels, factory, xrunner, Sorama, David Hess, oPossum and 11 Guests are viewing this topic.
Online zikeTopic starter
« on: Today at 10:57:07 am »
ya think?
ebay 366708551569
Offline negativ3
  • Country: th
Re: seller description: "Unit is in bad shape."
« Reply #1 on: Today at 11:00:36 am »
Hand tool rescue?
Online Greybeard
« Reply #2 on: Today at 12:29:45 pm »
Minor signs of use, almost like new!  ;D
Online themadhippy
« Reply #3 on: Today at 12:59:06 pm »
 that'll buff out
The following users thanked this post: zike
Offline lugaw
  • Country: jp
« Reply #4 on: Today at 01:03:19 pm »
I can see he is telling the truth.
The following users thanked this post: Manolo Mos
Offline DrijSkij
« Reply #5 on: Today at 02:16:14 pm »
It's hard to see the exact model number and the configuration.
I have a similar model HP that I dumpster dived from work. It's a 20V, 10A supply. It (predictably) needed 2 caps replaced. It dates back to 1974-75.
Online mbeldyga
« Reply #6 on: Today at 02:38:00 pm »
I'm afraid this unit may require more than just recapping ;D
Online golden_labels
« Reply #7 on: Today at 03:05:46 pm »
For intentionally damaged equipment this one is an unexpectedly good shape. They must have hired an amateur to perform item reclassification.
Why 📎 | We live in times when half of people have IQ below 100.
Offline Seekonk
« Reply #8 on: Today at 03:28:42 pm »
That is why I only buy equipment that is Certified Not Ready For Use!  Don't buy just random old equipment.
I did once buy a piece that must have been stored next to some sand blaster filled with sand and stored outside.
Offline squadchannel
  • Country: jp
  • deepl translate user
« Reply #9 on: Today at 03:58:20 pm »
All you need is a hammer. ;D
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #10 on: Today at 03:58:50 pm »
I can fix that.
  • Country: jp
« Reply #11 on: Today at 04:11:18 pm »
Me too!
« Reply #12 on: Today at 05:23:38 pm »
Was thinking to buy it just to punk UPS with a "damaged shipment" claim. But that would just make trouble for some random driver whose life's already hell.
Second thought, I've been through this experiment numerous times (against my will); and they never did anything at all.
Never mind.
Offline BigBoss
« Reply #13 on: Today at 05:37:49 pm »
If I were in the US, I would buy ..
Online factory
« Reply #14 on: Today at 05:42:33 pm »
99.99% certain the transformer will need a rewind, as it's right below where it took the impact, the PCB might also be crushed/cracked below this transformer.
The panel meter might be OK, the bezel falling apart is common for these, surprizing the terminal posts & rotary controls aren't smashed.
« Last Edit: Today at 05:45:21 pm by factory »
Offline the Chris
« Reply #15 on: Today at 05:57:12 pm »
How's the saying again?
"When all you have is a hammer, everything looks like this "
Online Stray Electron
« Reply #16 on: Today at 07:42:00 pm »
   That looks like some of the stuff that I've received from UPS!
« Reply #17 on: Today at 08:39:50 pm »
For anyone that hasn't worked on one of these, they weigh about 30 lbs. The PT spans the middle (the CG is below where they put the handle) and is sandwiched between structural bulkheads that subdivide the chassis, like a submarine hull. It's literally built like a ship. Merely dropping one off a tall building might dent the corners, but it wouldn't do this. You'd need a hydraulic crusher or a powered drop hammer.
So yeah, I'm pretty sure it was intentionally destroyed.
« Reply #18 on: Today at 08:49:52 pm »
I have little doubt it’s intentional. But it’s also very little damage for this kind of procedure. Whoever did that, forgot to apply the sledgehammer treatment to connectors and knobs. Sloppy job!
