Look for low ESR, high frequency, and high ripple current capacitors intended for switching power supply applications. I like the Nichicon PW series for general use but there are many options.
Not at all, if you replace capacitors, buy common capacitors of good brand, no need to be low ESR.
But buy those capacitors from reliable electronic parts suppliers NOT FROM EBAY...!!!!
Why it is not neccessary and even wrong to replace the capacitors by special low ESR capacitors ?
Some people suffers what I call "ESR madness".....It seems that ESR is the name of some godess and that they are repeating again and again their prays to the adoration of this godess...
1) Look at the Service manual of 2235: you have the list of replaceable electrical parts of A1 with all the specifications of the components....none specification of low ESR capacitors...!!!!
One of the rules in repairing is to respect the technical specifications of the manufacturer when you replace a component....Not better, not worse component, only the same as specified.
Could replace a component by a better one cause any harm ?
Yes, it can: I have here a Marantz Model 170dc to repair...It has beeing repair before and the "clever" guy has replaced some transistors by new ones, other types than what the manufacturer had recomended...
Those more moderne transistors has greater gain....What happen ? the power stage where he replaced the transistors is oscillating at about 2 Mhz...
2) What are the capacitors with high ripple current ? (NB: if there only low ripple current, for sure, there is no need of a low ESR capacitor)
- C906: has both ripple current of (120) 100Hz of rectified main's voltage and ripple from buck pre-regulator but ripple voltage on capacitor does not seems critical....there no specification of max ripple, nor test point on this capacitor.
- C925: has no ripple current but is very critical for leakage....should be replaced but low ESR is not needed.
- C940: Has both ripple current from the pre-regulator and from the square wave inverter T948. The square wave inverter has very low ripple current, its nearby dc current. Ripple current is limited by the inductance of T906. No high ripple current, no need to be low ESR.
- C944: very low ripple current because drive current of Q946 and Q947 is square wave. No need to be low ESR.
- C943: very low ripple current because collector current of Q946 and Q947 is square wave. No need to be low ESR.
- C942: no ripple current, no need to be low ESR.
- C968 : very low ripple current because square wave inverter and load not varying very much, not necessary to be low ESR.
- C970 : very low ripple current because square wave inverter and load not varying very much, not necessary to be low ESR.
- C960 : very low ripple current because square wave inverter and load not varying very much, not necessary to be low ESR.
- C961 : very low ripple current because square wave inverter and load not varying very much, not necessary to be low ESR.
- C956 : very low ripple current because square wave inverter and load not varying very much, not necessary to be low ESR.
- C954 : very low ripple current because square wave inverter and load not varying very much, not necessary to be low ESR.
