Working on a few units I got, hoping to put together one or two fully working if the other ones may become parts harvesters.
They all have slightly different signs of trouble, but essentially nothing works well, starting with non-sensical display annunciations. I'll stick with one particular unit for now to not confuse the conversation with inconsistencies.
Unit #1, hence, exhibits this inconsistent display of measurements. Typically, applying a certain excitation would change the screen somewhat, but information displayed would still be inconsistent and hard to interpret.
Here's some data I collected this far on this particular unit:
- The core voltage measurement stages are not working well (as I assume all other measurement modes boil down to this). I've followed the troubleshooting tree for DC voltage and I see no voltage present at U1601-pin15.
- In checking the clock, I enclose what I'm seeing at the base of Q1435 and the OSC input of U1603-pin8.
- I reseated the display board (access is quite tight, so I didn't pull it completely out, just enough to be able to apply some deoxit to the board pins and then pushed it back in.
- The PS rails seem to be close enough.
- I haven't checked the electrolytic and tantalum caps on the board, but given the health of the rails, I am not prioritizing these at this time.
- I reseated all ICs on sockets. To flesh that out a bit, I pulled them, sanded the pins a bit with an abrasive pen, cleaned them with IPA, then applied a touch of Deoxit with a swab.
- I've resoldered Q1415. Its solder points seemed to be pretty severely starved from solder.
- Access is not easy, but I've parsimoniously washed the switches with Deoxit. In hindsight, maybe I should have just tried an IPA wash first, particularly as that's less risky in terms of contamination. So maybe I'll give it another go with IPA on the switches, and seek to limit contamination with Deoxit oils on everywhere else than the inside of the switches (which will not be easy, I don't think).
The troubleshooting tree for DC Voltage is not too clear to me. For instance, what to do in case the U1601-pin15 levels are wrong (or non-existent).
