Author Topic: What is this SOT23-5 please  (Read 4530 times)
Offline cybermausTopic starter
« on: January 29, 2023, 07:47:45 pm »
I tried searching some SMD code bases, but I am not finding many DG at all
The item is on a camera sensor sub-board, and frankly the only reason it is suspect at all because it is the only one where I do not measure any junction pin 4
(red on ground, diode test method) All other SOT23-5 and all other diodes and capacitors measure OK.
I have to admit, it it is a bit if a last-ditch effort.
Offline fzabkar
Re: What is this SOT23-5 please
« Reply #1 on: January 29, 2023, 08:06:56 pm »
The following users thanked this post: I wanted a rude username
Offline mikerj
« Reply #2 on: January 29, 2023, 08:08:40 pm »
How old is the camera?  The code and marking match a V6310 reset controller, but it's an old part long out of production.
https://www.datasheets.com/en/part-details/v6310rsp5b--em-microelectronic-20195197
« Reply #3 on: January 29, 2023, 09:03:00 pm »
Thanks. It's an IP camera from about 2012
a high speed dome PTZ superzoom, so not entirely cheap.
fzabkar : A regulator at this location is unlikely. I would more expect some single logic gate.
Also, I do not see the marking in your suggested PDF?
mikerj :
It's unlikely to be the device you suggest, because while Vss seems to be correct, I have a junctions on what on your suggestion should be NC pins.
Also, but this may be my unfamiliarity with SMD codes, but your PDF shows DG# for 3-letter code option, but a completely different 4-letter code option, and I have a 4 letter code.
« Last Edit: January 29, 2023, 09:07:28 pm by cybermaus »
Offline fzabkar
« Reply #4 on: January 29, 2023, 09:20:58 pm »
The markings are not published in the PDF. They were provided by the smd part marking database.
Can you measure the voltages on the pins?
Are there 3 capacitors connected to this chip? If so, then that would be inconsistent with a logic gate, but would make perfect sense for an LDO.
Can you show us a photo of the whole PCB? Often it is better to see the part in context. Also, it may help to identify this chip if we can identify other chips. Often a designer will use a single source.
« Last Edit: January 29, 2023, 09:25:53 pm by fzabkar »
« Reply #5 on: January 29, 2023, 09:28:21 pm »
I see what you mean with the 3 capacitors, good point, I'll go check.
But the code in the database is only DG. 2 chars out of 4 seems a bit broad.
Unless of course if you see more because you are signed in? All I see is:  "DG" "Please login" SOT23-5
Offline fzabkar
« Reply #6 on: January 29, 2023, 09:35:54 pm »
Chips often have additional markings. "DG" could be the part ID, while "5" could be a year, and "v" could be a batch code.
The PDF icon has this URL:
https://www.onepcba.com/p/RT9178-30CBR
« Last Edit: January 29, 2023, 09:37:52 pm by fzabkar »
Offline timenutgoblin
« Reply #7 on: January 29, 2023, 10:06:25 pm »
I also think it's an LDO voltage regulator. There are bypass and decoupling capacitors.
See attachment below for pinout suggestion:
« Reply #8 on: January 29, 2023, 10:50:04 pm »
Yes @fzabkar and @timenutgoblin
It is indeed a LDO. The capacitors, as well as the 10K pullup resistor make it extra likely.
Also I figured out it came from a 5V switched regulator upstream, and injecting voltage there showed another short on another part of the board, causing this LDO to be starved.
Offline fzabkar
« Reply #9 on: January 30, 2023, 03:39:05 am »
There is a similar LDO here, but "DG" is associated with a 1.8V regulator in a different package.
https://www.vishay.com/docs/74442/sip21106.pdf
This "DG" part is a 2.1V LDO in a SOT23-5 package:
https://pdf.datasheet.live/29eb28f9/anachip.com.tw/AP131-33WA.pdf
« Last Edit: January 30, 2023, 03:45:44 am by fzabkar »
« Reply #10 on: January 30, 2023, 02:54:59 pm »
It is definitely and indeed a regulator, with the above common pinout, and it makes 2.85V out of 5V, and it is still in working order.
In the mean time I traced the problem to another chip that is shorting, and the camera is a loss.
Thanks everyone.
