Author Topic: "Batterizer" claims to increase disposable battery life 8x...  (Read 17128 times)
Offline westfwTopic starter
Offline Lightages
  • Canadian po
Re: "Batterizer" claims to increase disposable battery life 8x...
« Reply #1 on: June 02, 2015, 04:25:25 am »
Well the article makes some contradictory statements. It says you only use 20% of the battery and this device give you the rest, or 80% To me, that claim means you gain another 400% or 500% depending on how you want to make the calculation, not 800%. The other thing, is what semiconductor that would be used for this device would work below 0.5V? The claims are either made up, lies, or bad math. You are likely to be able to double the life of a cell which is still a good thing, but 800% more is a joke.
Oh yes, I need to add:
The battery and device will not be able to produce the same output in amps as the native battery. I also seem to remember that the chemistry does not allow the same amount as discharge as is being claimed.
« Last Edit: June 02, 2015, 04:28:12 am by Lightages »
Offline Muxr
« Reply #2 on: June 02, 2015, 06:57:26 am »
Not a new concept, classic jewel thief circuit (voltage booster) perhaps, it's easily feasible. Except doubt it could fit in that form factor as it requires an inductor, and a few other parts, so probably vaporware.
Offline miguelvp
« Reply #3 on: June 02, 2015, 07:09:15 am »
It's probably a Relaxation Oscillator, not an Amstrong Oscillator AKA Joule thief
w2aew made a video of a similar device but with larger components.
Online AndyC_772
« Reply #4 on: June 02, 2015, 07:16:24 am »
I suggest taking a look at the Enpirion range of dc-dc converters. Unfeasibly small, and their inductor is included within the package.
Offline jwm_
    • Not A Number
« Reply #5 on: June 02, 2015, 07:17:26 am »
Doesn't seem that crazy as a concept, many older or inexpensive devices do cut out or perform less optimally as soon as voltage just starts to sag well before the battery is dead.
It is just under very,very specific circumstances that this device will help and they are quoting really best case behavior all around for the right combo of battery and device.
Boosting 1.2 rechargable batteries up to 1.5 volts will also make it possible to use them in more places so seems handy just for that.
But no, it won't magically create 8x more energy, you have to already be wasting that much for it to reclaim it, 8x seems like a whole lot, but i could see getting a bit more juice out of batteries with this.
Offline matseng
    • My Github
« Reply #6 on: June 02, 2015, 08:19:26 am »
Doesn't the ESR normally shoot through the roof when they are discharged enough when most devices would consider them empty?
This would mean that they might be able to power a LED in a joule thief, but they really can't be boosted up and used in anything that uses more current than a few (or a few tenths of) milliamps...
Offline KiwiDaz
« Reply #7 on: June 02, 2015, 08:55:48 am »
In the words of the great Dave: "I smell bullshit"
It'll probably hasten the original cells drop from 1.5 to 1.4 in low draw devices,
And not able to extend high draw device lifespan by anything worth while.
All the while, producing a supply with plenty of ripple without a big cap on it.
Offline FrankenPC
« Reply #8 on: June 02, 2015, 11:26:06 am »
I JUST read this on Macworld.   This smells like EPIC bullshit.  Epic.
http://www.macworld.com/article/2928997/batteriser-is-a-250-gadget-that-extends-disposable-battery-life-by-800-percent.html#tk.rss_all
Bob Roohparvar tells a killer story of industrial espionage. The robbery occurred at his Batteroo office space in a sprawling Silicon Valley office park. The target was intellectual property surrounding Batteriser, a simple metal sleeve that promises to give consumers up to eight times more life from their disposable batteries, AAA through D.
batteriser verticalBATTEROO
The crooks clearly knew the building layout, and exactly what they were looking for—namely, a breakthrough technology that could blow the lid off an alkaline battery industry that’s worth $3.4 billion annually in the US alone.
“It was a very, very professional job,” says Roohparvar. “They passed by all the offices with open doors, and then banged the hell out of my door, breaking it in. The doorknob was slammed so hard into the wall, it got stuck in the plaster. They took my hard disk and a bunch of USB drives. They took our Batteriser samples. They knew exactly how much time they had before the police would respond.”
Chinglish poetry: In the hot summer. In the car ran full steam. It tastes strange. For this worry? With this fan will bring you a cool summer. Suitable for all kinds of cars. Agricultural vehicles. Van. Tricycle.
Online artag
« Reply #9 on: June 02, 2015, 04:41:43 pm »
The story sounds like great PR. I don't believe it for a moment. I didn't believe the 80% unused figure either, but I was surprised to see how poorly many devices use batteries. "80% remaining" may be reasonable for some poorly designed devices, and that could include the apple keyboard illustrated.
Consider an alkaline battery discharge curve such as
http://www.powerstream.com/AA-tests.htm
You can see that if you discharge it to 1.0V, almost all the power is gone - it will collapse shortly after. But if you discharge it to only 1.3V (using the 100mA curve), you've used only about 25% of the capacity.
A well-designed device won't give up at 1.3V. But how many things have you tried to run off Nicads (nominal 1.2V, a bit higher when freshly charged) and found they only work for a very short time ? I've always assumed that's because they want alkaline-level voltage and die at around 1.2V.
So I don't think this is entirely unreasonable, and could allow certain devices to get more out of a battery, or better still, operate off a rechargeable. If they're truly only $2.50 I'll certainly give one a try.
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #10 on: June 02, 2015, 06:12:28 pm »
Checking my boots now.
Recharged Volt-Nut
Offline suicidaleggroll
« Reply #11 on: June 02, 2015, 08:52:09 pm »
That article makes my head hurt...
Let’s say you buy a new battery. You use it for a month and its voltage drops to 1.4. It’s now ostensibly dead at 1.4 volts, but if you slip on a Batteriser, its output increases to 1.5 volts for another month. That’s already a 2x increase in battery life.
Eventually the battery’s natural, unboosted output drops to 1.3 volts—but Batteriser keeps it at 1.5 volts for another month. Now you’ve realized a 3x increase in battery life. And so on, and so on. Roohparvar says Batteriser can continue to deliver a 1.5 volt charge in batteries that have discharged down to 0.6 volts. There are more than eight 0.1 volt steps between 0.6 and 1.5 volts, so, in grossly simplified terms, the Batteriser can extend operational battery life somewhere around a factor of eight.
:scared: :scared: :scared:
Offline AG6QR
    • AG6QR Blog
« Reply #12 on: June 02, 2015, 10:48:47 pm »
... snip story about theft ...
Then he goes on and says the stolen technology was protected by patent.  Patented technology is freely available from the patent office!  That's the deal on patents, you disclose the workings of your invention in a way that anybody can make it, and in return, you get the exclusive legal right to manufacture/license it for a period of time.
Maybe those thieves weren't so bright, after all.
I like the story about the keyboard batteries.  The old batteries were placed in these magical boost converters, and then, to prove that the converter gave the batteries more capacity, they point out that the software claims the batteries are now at 100%!  That's merely pointing out that the software is reporting a capacity based on the measured voltage.  The capacity as reported by that method can't be relied upon after the batteries have gone through a boost regulator.  It'll show 100% capacity until it suddenly drops off a cliff to near zero.
Offline miguelvp
« Reply #13 on: June 02, 2015, 11:00:20 pm »
FWIW here are some of those patent applications:
https://www.google.com/patents/US20120121943
https://www.google.com/patents/US20150056476
https://www.google.com/patents/US20150048785
Might be more but this was a quick search.
Offline FrankenPC
« Reply #14 on: June 03, 2015, 12:10:16 am »
This story is spreading.
http://www.geek.com/news/a-2-50-sleeve-can-make-batteries-last-8x-longer-1624112/
I think it's time for Dave to do a frontal assault on this one.  Not that Dave listens to me.  But people need to know this is bullshit.
Offline miguelvp
« Reply #15 on: June 03, 2015, 01:25:41 am »
Seems the last two patent docs on google are missing the images, here is a link to other sources:
http://www.freepatentsonline.com/20150056476.pdf
http://www.freepatentsonline.com/20150048785.pdf
Offline sync
« Reply #16 on: June 03, 2015, 08:06:51 am »
It's that batterizer not dangerous? On an alkaline battery the case is connected to the positive side. The metal band on the batterizer is connected to negative. And It looks like there are sharp edges. I smell shorts.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #17 on: June 03, 2015, 09:21:13 am »
If you short a penlite it becomes very very hot. Until it's depleted.
If your device thinks the battery is empty at 1.35 volts, the device is crap.
A penlite is not to be considered empty until the cell voltage (under load) is below 1 Volts.
Discharge cureves: http://data.energizer.com/PDFs/E91.pdf
Offline EEVblog
« Reply #18 on: June 03, 2015, 09:29:41 am »
I saw the story about 4 hours ago and was all revved upand started planning a video, but I had to head home, won't be back in the lab until tomorrow.
Offline ozwolf
« Reply #19 on: June 03, 2015, 09:35:27 am »
That's OK, gives you all night to do a slooooow burn.  Then tomorrow we add oxygen and watch you go off!!!
Can't wait to see the video!! :-DD
Ozwolf
I reject your reality and substitute my own.
Online artag
« Reply #20 on: June 03, 2015, 02:21:54 pm »
The pictures show an insulated cap over the positive battery terminal to provide a boosted output.
But have you ever looked at an apple magic mouse ? It has an annoying plastic shield in front of the positive battery connector which means it's unreliable unless you have a battery terminal that's a smaller diameter than the width of the hole, and taller than the depth of the hole. And the 1mm thickness of the device seems a lot for many battery compartments.
As noted above, I think there are a bunch of applications where this will get more out of the battery. But there are also many that have decent battery management to start with, and others that will not be able to support the dimensions. I hope the remainder are still a sufficient market.
Offline AG6QR
    • AG6QR Blog
« Reply #21 on: June 03, 2015, 05:14:19 pm »
One other concern:  What's the quiescent drain of this boost regulator?  For some very low-drain devices, or applications where the device is left switched off for long periods, will the quiescent drain kill the battery, or at least cause it to die faster than it would have died without the battery sleeve?
Sometimes the battery management really should be in the device, not in the battery sleeve.
Offline miguelvp
« Reply #22 on: June 03, 2015, 05:20:48 pm »
Agreed! battery operated devices are usually not on all the time, only a few are.
That alone will make this contraption useless for most cases, and the devices that are designed to be on all the time like a smoke detector or battery powered temperature controllers would have already adequate power management, or at least they should.
Offline FrankenPC
« Reply #23 on: June 03, 2015, 06:19:04 pm »
Well, that's it isn't it?  If using boost converters on the regulator side INSIDE the device was a great advantage, manufacturers would jump at it to get extended battery life.  I imagine that very low power devices could benefit, but not anything that has to continuously transmit signals or draw any real current.
Note: I'm not talking about using boost/buck converters on something like a RasPi to eliminate linear regulators due to increased efficiency.  Doesn't matter.  Dave said he's on this one.  We'll put this to rest fast.
« Reply #24 on: June 03, 2015, 06:29:14 pm »
Why would they?  They don't have to buy your batteries.  It IS a great advantage, the problem is the device maker doesn't care, it's the consumer that cares, but only after they've already bought the device.  It's the classic problem of the device maker being completely separated from the maintenance costs of the device.
Building construction companies don't have to pay your electricity bills in the summer, so they don't care about how much/little insulation is used unless you go out of your way to request it.  Instead they cut costs to minimize their bid, and you're the one that has to pay in the end if you didn't have the foresight to specify double/triple paned windows, extra insulation, etc.
Some devices could be advertised that they have minimal power consumption, but some can't.  Nobody is going to buy a TV because the box says the remote control batteries last twice as long as the competition.  Instead they just minimize cost and you're left swapping batteries every month, or buying your own universal remote.
« Last Edit: June 03, 2015, 06:37:45 pm by suicidaleggroll »
