Author Topic: FTDI driver kills fake FTDI FT232??  (Read 1282726 times)
0 Members and 60 Guests are viewing this topic.
Offline TheRevva
Re: FTDI driver kills fake FTDI FT232??
« Reply #1475 on: November 04, 2014, 07:44:18 am »
Also are you sure you converted my user name properly?
Yep, I'm sure...  I'm normally pretty good at numbers and my C&P skills aren't too shabby either... <Grins>
also you failing horribly at copyright law
I have to freely admit... IANAL...  However, I'm beginning to wonder.  Whom is it that's being ANAL???
I'm also normally quite good at performing at least a rough 'proof reading' of what I've typed before bashing on that "Post" button.
Some users don't bother and that's THEIR choice.
P.S.  This 'response' post is NOT intended to be interpreted as anything more than just 'poking more fun' at the continuing pointlessness of this thread.
If '696,055,300,608' (Copyright 1914) or any other reader chooses to interpret it differently, that's THEIR issue to contend with.
Offline a210210200
« Reply #1476 on: November 04, 2014, 07:55:47 am »
@TheRevva,
Tell them they are better off getting real RS232 PCIe boards, they are only about $30 for 2 ports.
Also some motherboards have RS232 headers, you just need the external connector on one of the external slots on the back side external slots.
You can even get mini-PCI express serial cards if you have a very compact case or even want to use a laptop in a very odd way.
http://ca.startech.com/Cards-Adapters/Serial-Cards-Adapters/4-Port-RS232-Mini-PCI-Express-Serial-Card-16650-UART~MPEX4S552
Offline a210210200
« Reply #1477 on: November 04, 2014, 08:00:52 am »
This isn't a kid forum, or is it? ????
Probably piece of cake for Dave to run sql statement like this on its own database, so let creative people learn fast keyboard typing :-DD
DELETE FROM eevblog_forum
WHERE user='Rufus ' OR user='a210210200' OR .... etc
It would more kid like to just delete people's accounts you don't agree with instead of actually saying words that mean things.
Offline TheRevva
« Reply #1478 on: November 04, 2014, 09:13:53 am »
My (totally worthless) $0.02...
I would have surmised from the slightly sketchy SQL code that the intent was to delete from the table containing all your postings and not to delete you altogether as a forum user.  (The question revolves around the schema of this 'hypothetical' eevblog_forum table - is it a table of users or is it a table of posts made by the users?)
Having said that...
While it's pretty darned plain to almost everyone here that I strongly disagree with much of what you've posted, I will equally strongly DEFEND your right to have posted it in the first place.  (No matter HOW 'wrong' you may have been... <Grins>)
Offline dannyf
« Reply #1479 on: November 04, 2014, 11:19:19 am »
I am completely against a210210200's position on this matter. However, s/he has been very consistent in presenting facts and logic (however I disagree with it).
About the paid FTDI shills [and unpaid trolls]:
Other than smearing your opponents, you have made no rational arguments backed up by verifiable facts and added nothing positive to this discussion.
I'm not coming back.
Thank you.
Offline Rufus
« Reply #1480 on: November 04, 2014, 03:16:33 pm »
The hardware bricked itself because it didn't correctly emulate the hardware it was claiming to be. The FTDI driver treats all hardware the same and could easily claim the operations which fakes brick themselves on may be required by future revisions of their silicon.
I guess you were not paying attention. The code they used is designed specifically to do an EEPROM write that will fail on their hardware
It does not fail on their hardware it is ignored - the design authority for FTDI silicon isn't you it is someone who works for FTDI.
Online zapta
« Reply #1481 on: November 04, 2014, 03:33:28 pm »
[/quote]
Rofus you are dodging his argument. He says that they did it specifically to reconfigure non FTDI chips.
Offline Batang
  • Country: my
« Reply #1482 on: November 04, 2014, 03:51:54 pm »
I don't know if it has already been suggested (104 pages, yikes) but you could use the EEPROM tool from FTDI to reprogram the VID = 0403 and PID = 6001
Cheers
Offline free_electron
    • SiliconValleyGarage
« Reply #1483 on: November 04, 2014, 03:59:05 pm »
on the 'ownership of numbers'
the VID / PID pair is handed out by the USB consortium. it is assigned to one 'entity'. you cannot willy-nilly use someone else's number.
the numbers are used to match the device to the driver.
anyone stepping on someone else's number creates a problem.
there was a case w hile ago with some DAB driver that used the default cypress VID/PId for their USB-FX2 chips. the problem was , once that driver got on your system all your devices using an FX2 were recognised as a dab player. since the FX2 , on power up , enumerates using the cypress vid/pid to get it's firmware : nothing worked.  this cause a big stink and microsoft already had to pull a driver from their whcl base.
let's all play by the rules for once ok . they ain't that hard.
Wanna make usb product? then either :
- use standard chip with manufacturer provided driver and be done with it. no need to buy a vid/pid
- get your own VID from USB.org and write your own driver.
don't mix and match. and certainly don't use anyone else's vid/pid pair.
Offline Batang
  • Country: my
« Reply #1484 on: November 04, 2014, 04:09:39 pm »
RE: on the 'ownership of numbers'
The PID/VID numbers I posted belong to FDTI
http://www.ftdichip.com/Support/Utilities.htm
Cheers.
Offline AJ
    • GridTrak Open Source PMU Project
« Reply #1485 on: November 04, 2014, 04:33:53 pm »
Just my comments, Looking back...
A few years I had a problem with IOGear RS232/USB converters causing BSODs in Windows in one of my projects.  The following is the URL to my trouble ticket:  http://gridtrak.codeplex.com/workitem/9604
At the time, the only RS232/USB converter I could get to work reliably was FTDI based.  From then on, I was a loyal FTDI customer!
It took me several months of testing and learning the hard way to trust FTDI.  However, if at the time I was testing the RS232/USB converters, had I discovered any completely failed devices After testing FTDI devices - and I suspected FTDI drivers as the cause for the failures in the other devices, I would have abandoned FTDI products as being fatally unreliable.
My point is:  I agree with the majority that bricking devices on PCs is a bad idea.  And, if it ever happened to me, I would never use products from that company again.
I'm only a little concerned that all of the GearMo FTDI based RS232/USB devices I deployed to the field might start failing - because they did not come with any certificate of conformity and I bought them on Amazon.com; which may not be a FTDI distributor.
//AJ
« Last Edit: November 04, 2014, 04:40:06 pm by AJ »
//AJ
Offline Rufus
« Reply #1486 on: November 04, 2014, 04:41:53 pm »
I'm sure they did but what they do they do to all hardware. They make no distinction between genuine and non-genuine chips - the chips themselves make that distinction. They may well have chosen to do it that way because of legal implications despite it not allowing owners of non-genuine chips to be better informed.
Offline Bloch
« Reply #1487 on: November 04, 2014, 04:49:57 pm »
It is very expensive you need to buy them.
"The annual membership fee is US$4,000" from http://www.usb.org/developers/vendor/
http://hackaday.com/2013/10/22/usb-implementers-forum-says-no-to-open-source/
There was also a great talk about then big usb problem but i cant find the link.
Quote from: free_electron on Today at 02:59:05 AM
« Last Edit: November 04, 2014, 04:54:27 pm by Bloch »
Offline edavid
« Reply #1488 on: November 04, 2014, 05:01:10 pm »
If you make a device that's compatible with an existing driver, it's much better to use the same VID/PID.  It doesn't benefit anyone to have duplicate drivers with different VID/PIDs.
Using someone else's number doesn't create a problem if the devices are compatible, in fact it's better.
Nice story, but not relevant to the FTDI situation.
Too bad those rules don't cover the FTDI situation:  make a chip that's compatible with a standard chip... then do what?  USB doesn't have an answer for that.
« Last Edit: November 04, 2014, 05:47:40 pm by edavid »
« Reply #1489 on: November 04, 2014, 05:27:57 pm »
Yep, the thread has (quite rightly IMNSHO), become somewhat of a joke...  (In fact, for some of us, it was somewhat of a joke right from the outset)
That 'joke' status is exactly the reason why I've elected to 'claim ownership' of the numbers '7' and '823543'.  (I hope it put a smile on at least SOME faces?)
BTW, if anyone is willing to pay me US$5000.00, they can 'claim ownership' of any other numbers.  (I'm tempted to put dibs on numbers like PI and 'e' since they're bound to be worth a 'premium price'.  Perhaps I should also claim 22/7 for those 'rationalists' amongst us?).
Each of us will make our own decisions based upon what we have seen and read (in combination with our own unique 'personalities') and life will go on irrespectively.
If nothing else, I'd suggest that FTDI management will think VERY hard of the ramifications of any such future 'releases'.
If you look into pi long enough ( or e for that matter) you will find a section that is every imaginable number. Are they going to ban these 2 numbers?  Legislate it is equal to 3? Very hard to patent or copyright a number, which is why we have the Pentium, as I am looking at an IBM 6x86 processor on the shelf next to me. Intel lost that legal battle big time to big Blue and AMD.
Offline edavid
« Reply #1490 on: November 04, 2014, 05:47:09 pm »
It is not known if pi and e are normal.
http://en.wikipedia.org/wiki/Normal_number
Offline miguelvp
« Reply #1491 on: November 04, 2014, 05:52:25 pm »
Doesn't FTDI provide their customers PIDs while still using their VID?
So you can still do your own driver and get your PID gratis.
http://www.ftdichip.com/Support/Knowledgebase/index.html?caniuseftdisvidformypr.htm
Offline Rufus
« Reply #1492 on: November 04, 2014, 05:59:14 pm »
The answer is don't. How do you control unique serial numbers on compatible chips? If you plug in two devices with the same serial number Win XP immediately BSOD's for example.
Offline nctnicoTopic starter
« Reply #1493 on: November 04, 2014, 06:55:29 pm »
It doesn't (been there, done that). It just enumerates both devices. Remember each USB port has a unique address within the USB device tree as well.
Offline Rufus
« Reply #1494 on: November 04, 2014, 07:25:37 pm »
http://blogs.msdn.com/b/oldnewthing/archive/2004/11/10/255047.aspx
In my experience "Exciting things happened" = BSOD.
Offline a210210200
« Reply #1495 on: November 05, 2014, 06:46:46 am »
You can get PIDs from other companies either for free (if you use their products) for small scale use or get a PID for yourself (without the blessing of the official USB group)
http://www.mcselec.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=92&option=com_phpshop&Itemid=1
But making a device which may be compatible now under the exact same VID/PID is not a good thing to do for the entire ecosystem since conceivably a non-DRM type change could break compatibility and cause system instability (BSODs) creating all sorts of problems which would be difficult to figure out. Finger pointing will result and in theory in a opposite day world a mistake of a "compatible" chip could cause a host computer to BSOD.
If your a company wants to do it properly so users get a plug and play experience you want to have control over both VID/PID and have a WHQL driver and so on your going to have to pony up the fees anyways otherwise Microsoft is just going to take your money. (Testing per os is non-refundable $250, probably adds up quick if you want the entire range and you need your own certificate for Microsoft software verification as well for an additional cost as well)
Offline a210210200
« Reply #1496 on: November 05, 2014, 06:55:24 am »
The problem with a compatible chip is who determines if it is certifiably compatible. Using a different VID/PID prevents problems like that even if they are using the same driver just one that is verified to work with the compatible chip. Example, Racepak (Racing Engine Diagnostics) and Bayer (Medical Devices) in two totally different industries distribute FTDI drivers but use their own VID/PID combination to maintain control over what driver users get as well as the device name and vendor information so that no consumer would be confused to think it is an FTDI device since windows reports it as whatever the mfg wants. An added bonus is that even if FTDI screws up or does something intentionally insane they still won't affect your product because windows has it locked in with your own WHQL driver with its own security cert and so on.
Even those this incident is clearly an action from FTDI there is nothing in reality that stops a "compatible" chip from getting a bad revision done that causes instability in windows without a driver update. Even though no one really owns the VID/PID space it technically should be respected to maintain a functional PnP ecosystem for USB devices in general. (There are plenty of numbers to go around)
Offline a210210200
« Reply #1497 on: November 05, 2014, 07:03:24 am »
Interesting thing about pi = 3 is that it works fine if your doing rough estimation.
Great example of such order of magnitude estimation, https://what-if.xkcd.com/84/
Very useful in sanity checks, early development calculations.
Offline TheRevva
« Reply #1498 on: November 05, 2014, 09:26:28 am »
<Snipped out a chunk> (There are plenty of numbers to go around)
Careful dude, those are very similar to 'the famous words' from MANY people / institutions...
Afterall who on earth would want more than 640kB of RAM (Supposedly uttered by 'some fool' from Microsoft)
And then there's the whole IPv4 debacle which has a positively HUGE 32bit address space...  Who could EVER have imagined we'd exceed THAT?
You may as well also include the good old bar codes (such as UPC / EAN13).  What single manufacturer would ever exceed 99999 unique products? Is 99999 unique manufacturers sufficient to cover the entire GLOBE???
Correct me if I am wrong, but my understanding that both the VID and PID are constrained to 16 bits each.  (Thus a range of 0-65535 each at best case)
It's only a matter of time...
(Just like it's only a matter of time before the signed 32bit 'time' counter in original *nix systems 'rolls over'...  Jan 19 2038 IIRC Sometime around 03:19)
Offline miguelvp
