Author Topic: good flux remover  (Read 17844 times)
Offline Homer J SimpsonTopic starter
good flux remover
« on: January 13, 2013, 02:53:38 pm »
Looking for a good non aerosol, flux cleaner / remover.
Please recommend a good brand, price and supplier for the US.
Id did some searching. Seems like most is in a spray can or sold in 1 gallon amounts.
Would be nice to find about a liter size.
Thanks
Re: good flux remover
« Reply #1 on: January 13, 2013, 02:58:06 pm »
I did find this...
http://www.stanleysupplyservices.com/product-detail.aspx?pn=411-872
Never heard of the manufacturer but that is basically what I am looking for.
I do have 99% alcohol but on some stuff it does not work that great.
KT
« Last Edit: January 13, 2013, 03:04:19 pm by Homer J Simpson »
Offline lewis
  • Nullius in verba
« Reply #2 on: January 13, 2013, 03:25:18 pm »
Electrolube Fluxclene is good stuff, Farnell has it here
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline jeroen74
« Reply #3 on: January 13, 2013, 03:40:11 pm »
I second that.
But ITW Chemtronics - Flux Off is pretty good too.
Online sotos
  • Country: gr
« Reply #4 on: January 13, 2013, 03:59:34 pm »
Flux Off is very good I use it a lot, also I use isopropanol.
Offline UPI
« Reply #5 on: January 13, 2013, 05:21:55 pm »
Same here. I use the 99% IPA at the bench and Flux Off in the ultrasonic bath.
We like these brushes on the bench:
http://www.mouser.com/ProductDetail/Techspray/2032-1BULK/?qs=sGAEpiMZZMtYFXwiBRPs04PSgpLK8qTW
http://www.mouser.com/ProductDetail/Techspray/2022-1BULK/?qs=sGAEpiMZZMtYFXwiBRPs02Vv/vrgmxLX
Offline nctnico
« Reply #6 on: January 13, 2013, 05:33:42 pm »
The Chemtronix flux-off works pretty well. However some types of bio-ethanol work even better but you have to be lucky and find the right stuff.
Offline (In)Sanity
« Reply #7 on: January 13, 2013, 05:34:48 pm »
What actually removes flux really well is Xylene.  BUT and this is a big BUT,   it always can discolor certain plastics.   I've never had it remove silk screen or do anything to IC's or other parts,   I have had it discolor power connectors and headphone jacks.   It absolutely cleans every single trace of flux away,   it ends up looking shinny and bright like it was professionally treated.   Again,   don't forget the BUT.
Denatured alcohol also works somewhat OK,  Isopropyl alcohol about the same.
Xylene however for me cleans as fast and as good as any commercial spray cleaner I've used,   just remember that BUT I mentioned above.   The good part about it is it's cheap and readily available at your local hardware store.   Ohh and another note,  don't use it indoors.
What I normally end up doing is de-fluxing with Xylene after all my main components are in place and then soldering in any plastic based items and just using a q-tip and xylene to clean the rest.    No need for an ultrasonic bath,  this stuff removes the flux instantly and leaves nothing behind.   A mild toothbrush can be used when in doubt along with it.
Have fun,  and as always my tips come without warranty.
Jeff
Offline AndyC_772
« Reply #8 on: January 13, 2013, 05:39:29 pm »
I have an old oscilloscope on the way from Ebay, which contains a whole load of electrolytic capacitors that are known to leak and die over time. I plan to replace the whole lot as soon as it turns up.
Anyone know of anything better than Flux-off for getting rid of leaked electrolyte?
« Reply #9 on: January 13, 2013, 10:23:58 pm »
well I checked out the Chemtronics web site.        http://www.chemtronics.com/home.asp
Here is their Flux Remover line of products.      http://www.chemtronics.com/products/americas/e/flux_removers.asp
There are 11 different products in the line.
What is the recommendation for best all around product.
Also, looks like if you what a non spray from them 1 gallon is the smallest you can get.
Thanks
Offline UPI
« Reply #10 on: January 13, 2013, 10:38:38 pm »
Flux-Off Aqueous Flux Remover used only in the ultrasonic bath. Gallon sized only.
http://www.chemtronics.com/products/product.asp?r=1&m=2&id=77
IPA does well when used with good brushes and vigorous action.
Offline (In)Sanity
« Reply #11 on: January 13, 2013, 10:44:53 pm »
Not bad for the price really.  I'll keep using Xylene of course until I one day damage something.  I should just find a mixture of Xylene and something else that makes the Xylene safer.  A ton of products use Xylene and don't harm plastics.  Many of your glue removers use it.   For the price however the official looking product is not a bad way to go.
Offline Smokey
  • Not An Expert
« Reply #12 on: January 13, 2013, 11:27:57 pm »
Just IPA and a little scrubbing with one of those small brushes gets the job done without anything too toxic or expensive.  The thing to keep in mind when using IPA (or probably any other solvent) is that once you put a little IPA on and dissolve the flux, you need to rinse that IPA away with more IPA or else when it evaporates you will have a bigger flux mess than when you started.  The post scrubbing rinse is the most important part, no matter what you use.  Just make sure all the parts like pots and connectors are wash rated before you flood the thing.
Offline nctnico
« Reply #13 on: January 14, 2013, 12:24:32 am »
Xylene doesn't sound very healthy to me. Even when its not highly toxic solvents do have a bad effect on the nerve system.
Offline mazurov
    • nerpa
« Reply #14 on: January 14, 2013, 01:06:31 am »
I'm using 2 step process. First pass is boiling in 70% IPA which takes out the bulk of flux residue, second final clean with 99% IPA in ultrasonic bath. Works very well.
With sufficient thrust, pigs fly just fine - RFC1925
Offline (In)Sanity
« Reply #15 on: January 14, 2013, 01:34:29 am »
Correct,  it's pretty nasty stuff.  It's also fairly widely used in many types of solvent cleaners.  I like it because it leaves the board and components incredibly clean looking without much work.   It also dissolves under a component as well.  It's never done any harm to IC's,  caps,  resistors..etc.  I wouldn't use it around trim pots all that much,  might mess with them.   I would say it's best used for spot work rather then full on showers of the stuff.   I've of course done both.
IPA followed with distilled water might work out well.  IPA followed by IPA of course does.   The problem I have with IPA is getting it to clean well between pins,  under stuff..etc.   When I built my SDR radio kit it didn't work as well until I got it spotless with xylene.  A buddy of mine used Chemtronics products on his kit and had just as good of results.   IPA just wasn't cutting it.
Food for thought.
Jeff
Offline UPI
« Reply #16 on: January 14, 2013, 01:52:42 am »
Sounds quite scary to me. Is it a critical application that requires such hazardous measures as heating and vaporizing a flammable liquid?
Offline cwalex
« Reply #17 on: January 14, 2013, 02:07:29 am »
I just use denatured alcohol and a brush like these: http://www.ebay.com/itm/12-Acid-Brushes-6-w-Horsehair-Bristles-for-Solder-Flux-Contact-Cement-etc-/300833757500?pt=LH_DefaultDomain_0&hash=item460b16d93c
I cut the bristles down to about 4mm or so the brush is a lot stiffer. Seems to work fine so far.
Offline mazurov
    • nerpa
« Reply #18 on: January 14, 2013, 03:10:09 am »
It's called process design. Water bath and stuff. 70% IPA is very cheap but it doesn't wash very well, that's why I'm heating it. Ultrasonic in second step is heated too, BTW, for the same reason.
I used to do first step in ultrasonic as well, but good wash took too much time, about 30 minutes, so I switched to boiling. It's not that scary, actually. I once had a girlfriend who designs microfabrication processes for a living. A young lady had no problem boiling acetone on a hot plate - that's how they wash off photo resist from the wafers.
Offline UPI
« Reply #19 on: January 14, 2013, 03:40:17 am »
I don't really mind the 30-45 minutes with Flux-Off in the heated ultrasonic since we only wash a few boards a week. I use DI water to rinse the boards afterwards. It is a relatively safe low volume solution.
I am genuinely curious:
What were the design considerations that made IPA the best solution?
Are a fume hood and fire suppression needed?
Offline cwalex
« Reply #20 on: January 14, 2013, 03:50:57 am »
I'm also curious why iso does a better job than denatured alcohol. I thought it was just the same thing (ethanol) with something added that makes it so you can't drink it. I emailed the company I get my denatured alcohol from and they assured me the additive is in such small quantities that it will not affect anything, he didn't say what the additive was just that it isn't methanol like I thought it might be. He wouldn't say what it was, I got the feeling he didn't know or just didn't want it public knowledge.
Offline mazurov
    • nerpa
« Reply #21 on: January 14, 2013, 03:51:40 am »
What do you do with Flux Off and DI water after you're done washing?
Offline mazurov
    • nerpa
« Reply #22 on: January 14, 2013, 03:54:10 am »
I can't use such chemicals. I need to know what's in it or at least an exact list of "anything".
Offline cwalex
« Reply #23 on: January 14, 2013, 03:59:25 am »
As usual I should have done my research before posting  :palm:
This wikipedia article is very informative: http://en.wikipedia.org/wiki/Isopropyl_alcohol
Looks like I will be buying a litre or so of it next chance I get.
Offline FenderBender
    • The Solid State Workshop
« Reply #24 on: January 14, 2013, 04:10:49 am »
I bought some 99.95% Isopropyl Alcohol. I let my boards sit in there for a minute or two. Then take it out and scrub it using a tooth brush, then put it back in the IPA. Then take it out and put the board under running water with a tooth brush and it works great!!
