Author Topic: Microphone recommendation for finding sources of noise in electronic equipment  (Read 6504 times)
Offline matthuszaghTopic starter
I sometimes come across a piece of test equipment that produces annoying high-pitch audible noise. It's often difficult to locate the offending component without additional tools. So, I'm thinking of purchasing a microphone that I can use with an audio-frequency spectrum analyzer (probably an HP 3585A) to help locate these noise sources. Any recommendations?
Some preferred requirements:
1. Small, so it can reach into tight spaces.
2. Electrically insulating, so I don't accidentally short something out. If needed, I can place heat shrink over it (if I do this over the microphone part, I'll have to see how much this degrades the performance).
3. An articulating arm would be nice. But at the very least something that has some rigidity.
4. It should cover at least close to the full range of audio frequencies. I don't know the maximum frequency I can hear, but I'm relatively young so it's probably near the higher end.
I have almost no experience with audio electronics, so if I need a preamp for it too, recommendations for that are also appreciated. Without a preamp, I was planning to plug it into the high-impedance input of my 3585A due to the fairly high microphone source impedance.
It doesn't need to be very high performance since this is for simple troubleshooting.
I'm happy to construct or modify something myself if that's the best bet. For example, maybe this would involve purchasing a microphone and articulating arm separately and constructing a complete unit from that.
Any other thoughts such as other ways to locate these noise sources also welcome. And, if anyone else has something they use for this purpose I'd be interested to hear it.
From a quick look, it seems like pulling the microphone from a headset could be a good bet, but it would be good to have information about the frequency range the headset's microphone supports.
Offline nctnico
What you need is a stethoscope for (car) mechanics. Works like a charm.
That does sound ideal - thanks. Do you know the frequency range of the sensor? I expect most medical stethoscopes operate with low audio frequencies in mind, but I would imagine mechanic stethoscopes would be designed to support higher frequencies. I can't find much information on that though.
Also, the sensors look like metal rods. Any idea how their function would be affected if I insulated them (e.g., heat shrink or a rubber coating)?
« Last Edit: December 23, 2024, 07:23:11 pm by matthuszagh »
Offline Sorama
We have an acoustic camera for analysis of building acoustics ald finding air leaks in walls or windows and wonder if it would suit for this also.
Super cool! Didn't know those existed. But they seem well out of my price range, unfortunately.
Offline Sorama
There are indeed expensive. Ours is about 15k.
Offline TheoB
A simple phone app can act as an all in one audio spectrum analyzer. Try for example Spectroid. An external small microphone can also be used like the one present in a headset.
« Last Edit: December 23, 2024, 08:40:21 pm by TheoB »
Offline Coordonnée_chromatique
How can we localize a sound with one microphone ?
The signal gets stronger when the microphone is closer to the source of the noise and weaker when it's further away.
Here we should face a sensitivity problem IMHO
« Last Edit: December 23, 2024, 09:08:38 pm by Coordonnée_chromatique »
Offline Gyro
The simplest way, and probably cheapest, is to attach a length of thin plastic tube to the front of a small microphone (probably electret) in an airtight manner. Sound will pass down a considerable length of tube with reasonable frequency response, think in terms of the long tube acoustic headphones used in MRI scanners.
If you need more steerability, tape an insulated length of thin garden wire to the outside of the tube.
Best Regards, Chris
Have you an idea of the frequency response and the sensitivity of this soluition ?
Offline Gyro
Sensitivity is as good as the gain on your microphone. Frequency response isn't going to he Hi-Fi, but should be good for reasonably high frequencies. It's an old car mechanic's trick to use a thin length of hose, one end in the ear, to listen for the high pitched hiss of small air leaks etc.
Best Regards, Chris
The following users thanked this post: Roehrenonkel
Offline richnormand
If you can hear it: I use a tygon hose. One end on my ear the other to probe around the circuit.
Provides electric isolation and pinpoints the specific component.
Otherwise the electrec microphone and a scope is a good idea but I would still use a length of hose to isolate electrically and pinpoint the component.
Many of the car stethoscopes require contact to the surface. Not a good idea in PSU and such.
« Last Edit: December 24, 2024, 06:13:41 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline themadhippy
If the idea of shoving a raw bit of tube in your ear dont appeal theirs plenty of ear pieces with a tube attached , 1 random example https://www.amazon.co.uk/sourcing-map-Acoustic-Earpiece-Replacement/dp/B0BG87C4XD
Offline RoGeorge
Try bone conduction.  For example a wood chopstick in touch with the ear cartilage (kept with the hand), while with the other end touch it to the presumably singing coil.
IMO you should investigate a little before choosing any technical solution, the sound propagation in the air is not the same that in solids and it is presumptuous to correlate them so early, moreover in the audible range the short waves are very easy to diffract and refract especially on a very populated PCB with a lot of thermal gradients.
Could you describe how is your noisefloor ? level and distribution ?
Could you describe how is your noise ? have you already tried to record any of this noises when you've succed to find one ?
Offline RoGeorge
If it has to be a microphone (and not just a passive stick used as a bone conduction hearing aid), then I would use an electret microphone.  They are very small, cheap and easy to use.  Can be recovered from defective headsets, or from 2/3G mobile phones, fix phones, TVs/boomboxes, etc., electret mics are almost everywhere.  Some are as small as 2-3mm in diameter.
Many may work as high as 100kHz or more.  If you like more fun with that, try an audio heterodine, and you'll can hear ultrasounds and bat ecolocation barks, too.  Here I did something else, used the comparator of an ATtiny13 instead of properly amplifying the analog sound, then a counter to divide the frequency, like this:
The image is from this other topic https://www.eevblog.com/forum/projects/want-to-hear-the-bat-flying-in-my-front-yard/msg5582713/#msg5582713 where you can find, too, the code for the microcontroller.  It is for a MEMS (still analogue) microphone, but should work as well with an electret microphone.
Same as before, use a thin wood/plastic stick (anchor the microphone at the tip of a baguette), to make an audio probe.
If you order instead of scraping old microphones, beware that most recent models may be digital, but there are plenty of analog electret microphones still in production.
« Last Edit: December 24, 2024, 08:50:31 am by RoGeorge »
Offline al777
My vote also goes for an electret microphone, followed by a simple amplifier. Attached are photos of my solution, I've built it exactly for the reason of weeding out a whiny ceramic capacitor on an LCD panel "scaler" board. I gave it local battery power and housed it in a metal enclosure to avoid any chance of EMI hum. The Plastic tube is a body of a BIC ballpoint pen, guts removed. The microphone was from an old wired mobile headset. Be careful when soldering it, they are easily ruined by overheating.
In my experience, having the acoustic probe for scope helps with remediating the problem, not only identifying an offending component. Sometime the component is not faulty, while the design/manufacturing decisions are :-). Hence it's very useful to actually see what is the signal that you are hearing, such as some DC/DC conversion frequency will show clearly in the acoustic domain, and you can use second scope channel to see the electrical domain at the same time - that way you know what is going on and can try to mitigate the root cause of the problem. In some cases I've seen it was not a faulty capacitor, but simply an underspec-ed one... or several... economy is driven by MBAs :-). So, replacing it with the same value would not get much effect (although one could try to use more expensive caps with interposer substrates, like some of muRata's series), but bumping the capacity back to what the datasheet has suggested may help :-).
Here is a link to muRata's related article: https://www.murata.com/en-us/products/capacitor/ceramiccapacitor/library/apps/notepc
Happy holidays to all!
The following users thanked this post: matthuszagh, cte, 5U4GB
Is there any ready made product of this probe ?
Offline al777
If you are asking about my probe (photos above) - then sadly, no - it is a one-off "custom tool" I've made to extend my line up of probes when a need arose... it joined a pair of other probes in the same form-factor, optical probe and Hall-effect current probe... I'm not aware of a ready-made version for sale anywhere, but I wasn't searching :-)... I just made it, it was faster that way :-)...
Offline 5U4GB
I've used a Dodotronic UltraMic, no direct link but they're available from all sorts of sources although the price seems to have gone up a bit since I got mine many years ago.  Has a rubber cap so you won't short anything out by poking around with it, and a USB interface for connecting to more or less anything.
« Last Edit: December 25, 2024, 05:08:47 am by 5U4GB »
The following users thanked this post: al777
There is not "tube" on this microphone, could you tell what is the purpose of a tube, it is a kind of helmholtz amplifier for an already known frequency range ?
Offline Georgy.Moshkin
  • Country: hk
  • They talk. I build.
    • My Online Courses
IMO sound pressure may be kind of stronger at some points that are farther from the source. In a sense that close-range measurements are too sensitive to the microphone orientation and position. What about a toothpick coupled to some piezo or microphone, makimg it a contact measurement: couple the vibration from some chip capacitor directly to the sensor.
Check my online courses on Udemy
Offline nctnico
You actually need the contact measurement to pinpoint the actual source. A piece of plastic pipe does the job for insulation if necessary or find a plastic stethoscope. In many cases it is the board itself which propagates the sound, you need to find the part which causes the board to vibrate.
