That same station was over $300 on Amazon so I originally skipped it.
Pure insanity at that price. You'd be able to get a better performing station with some very nice extra features, particularly regarding standby settings.
I'll try Hisco.
Make sure they have stock in Canada, as it may only be a business office.
Do note the Hakko distributor page I linked in my previous post if Hisco doesn't pan out.
For the tip, how is the default one that comes with it?
It comes with a T18-D16, which is a 1.6mm chisel. As per quality, Hakko's tips are well made (thick plating, so they last years if cared for properly).
It does say it's a chisel tip which I think is what is preferred for every day use right? I might just stick with that for now. I was trying to find other tips on Hisco but they all seem to be for very specific models.
Chisels do make good general purpose tips, but you'll need more than one size (i.e. 1.6mm, 2.4mm, and 3.2mm for sure, and perhaps one larger & smaller), and a couple of other profiles will likely be of use as well. Particularly as you get into SMD.
Hakko's Tip Selection Page might be of particular interest for you (how to select size & what, when, and how to use the different profiles).
For tips, you'd be looking for the T18 series (
Hisco has them here).
