Hi, can someone help me with connecting a 210 iron to a black V3.1 F103 Ksger board. I have successfully flashed the CFW and my 5pin T12 iron functions great. But when I try my cheapo AliExpress 5pin (3 connected and 2 of them bridged) 210 iron I get a 1Hz clicking sound from the iron. I have tried to cut the bridge, but still the same sound. I have also changed the menu from T12 to 210.
It seems like different boards have different 5pin configuration, and there is also some confusion online because some sees the pins from the back, some from the front, and some sees from the end of the cable, so sometimes it gets mirrored. Some of the pinouts uses the 6 pin Hirose connector instead of 5 pin GX/aviation plugs. I also wonder which pins to bridge, if any on the 210.
I have attached pictures with pin numbers and iron contact points to make everything clear, pin 1,2,3,4,5 (seen from the backside, same side as the cpu) and iron contacts A,B and C. Thank you.
UPDATE: It seems like my problems came from using irons made for those 5V battery driven irons, they where wrongly labeled as C210 and looked the same, just without the plastic insulator between point B and C. My mosfet died violently but after changing mosfet and using the proper C210 irons everything seems to work as intended, at least initial testing went well but I havent had the time to use it yet. And the 1Hz clicking sound went away together with the error msgs.
